| E9 - color placement - what color goes where? | ||
| The main premise of this thread is to get things painted correctly, if you are striving for the look of originality. I am sure there will be some debate about certain items, and that discussion helps us all have better examples. So this is a work-in-progress. I have been collaborating with our friends HB Chris and Markos. | ||
| BODY EXTERIOR | ||
| These items - body color | ||
| 1. All topside panels welded to the body | ||
| 2. doors, hood + trunk | ||
| 3. Inner wheel wells | ||
| 4. gas flap and hinge | ||
| These items - body color with schutz (texture) | ||
| 1. Lower front valence - below chin panel (below bumper) follows indent line | ||
| 2. Lower rear valence (below the centerline of the bumper) - follow the inset line | ||
| These items - painted satin black with schutz (texture) | ||
| 1. Rocker panel covers | ||
| These items - painted satin black | ||
| 1. Bumper brackets | ||
| 2. cover panels within wheel wells | ||
| These items - painted sign painters' lettering enamel 154-L peacock blue or 153L process blue | ||
| or blend of Testor's 1108 light blue and 1110 blue - rgb (0, 138, 201) | ||
| 1. Roundel Blue | ||
| These items - Testor's 1145 white | ||
| 1. Roundel White | ||
| These items - Testor's 1147 Black (semi gloss) | ||
| 1. Roundel Black | ||
| 1. all items welded to the body, including fixed radiator mounts1. | ||
| 2. hood | ||
| 3. head light access covers | ||
| 4. hood support / bracket arms and bolts | ||
| 5. hinges + hinge bolts | ||
| These items - satin black | ||
| 1. Radiator | ||
| 2. Radiator side bracket (removable) | ||
| 3. Brake Booster and mount | ||
| 4. Wiper Motor and mounting bracket | ||
| 5. PS pump | ||
| 6. PS reservoir body & cap | ||
| 7. Hydraulic Steering box | ||
| 8. A/C muffler and drier | ||
| 9. Heater intake cover | ||
| 10. Hood latching catches | ||
| 11. Metal Coolant overflow tank | ||
| 12. Plastic plug at hood release cable | ||
| These items - warm grey with green tint (RAL 7043) - close, but not perfect | ||
| 1. Air cleaner | ||
| These items - warm grey with green tint (RAL 7022) - close, but not perfect ... some say RAL 6015 is better | ||
| 1. Csi airbox | ||
| These items - dark gray with greenish tint (RAL 6015) | ||
| 1. Subframe | ||
| 2. Strut housings | ||
| These items - painted Tamiya Color code TS-34 Camel Yellow | ||
| 1. Dipstick hoop | ||
| These items - yellow zinc | ||
| 1. Hood light activation bracket | ||
| 2. Air filter box clamps | ||
| These items - not painted / clear zinc | ||
| 1. Hood latches | ||
| 2. Strut top bolts | ||
| 3. Wind shield wiper pushrod arms | ||
| IN THE TRUNK | ||
| 1. all items welded to the body | ||
| 2. trunk lid | ||
| 3. torsion bars, support arms and bolts | ||
| 4. hinges + hinge bolts | ||
| 5. trunk stop brackets | ||
| 1. torsion bar clips | ||
| 2. gas tank | ||
| 3. gas filler pipe | ||
| 4. spare tire hold down bracket | ||
| These items - not painted (clear zinc finish) | ||
| 1. Trunk latch | ||
| 2. Trunk latch mounting bolts | ||
| 3. Trunk lid catch | ||
| 4. Spare tire nut | ||
| Trunk trim - painted SEM Storm Gray | ||
| 1. Elephant skin trunk panels and floor boards | ||
| 2. Tool box | ||
| 3. Taillight covers | ||
| Trunk trim - painted SEM Ranger White | ||
| 1. Panel edge trim | ||
| INTERIOR | ||
| 1. All visible body metal welded to the body | ||
| 2. door hinges, bolts / screws | ||
| These items - painted satin black - (SEM 39143 Trim Black) | ||
| 1. removable metal panels below windows (that wood mounts to) | ||
| 2. Hand brake lever + bracket | ||
| 3. Steering wheel hub | ||
| 4. exposed portions of steering column (with texture - SEM 39793 - Heavy Texture Chip Guard) | ||
| 5. A/C panel (with texture - SEM 39793 - Heavy Texture Chip Guard) | ||
| These items - krinkle black | ||
| 1. Metal steering column covers | ||
| 2. instrument surrounds | ||
| These items - unfinshed (clear zinc) | ||
| 1. door brake (flat bar) | ||
| 2. door latch | ||
| 3. front seat sliders and lever control | ||
| 4. visible door fasteners (other than hinge screws) | ||
| Trim pieces - painted SEM Satin Black (or Landau Black) | ||
| 1. Dash | ||
| 2. Dash instrument binnacle | ||
| 3. Dash Grab rail | ||
| 4. Glove boxes | ||
| 5. Underdash panels | ||
| 6. Console sides | ||
| 7. Dash top vinyl | ||
| 8. Vinyl trim above wood (doors + rear) | ||
| 9. Grab handle (rear seat) | ||
| door break (flat) rod | ||
| Trim pieces - painted interior color | ||
| 1. Kick panels (if not leather) | ||
| 2. Door + Rear Side panels (if not leather) | ||
| 3. Door pulls | ||
| 4. Rear armrests (if not leather) | ||
| 5. Welts between door panel and door | ||
| Trim pieces - painted SEM ranger white | ||
| 1. Headliner | ||
| 2. Headliner molded panel | ||
| 3. Sunvisors | ||
