Two time E9 owner, first time forum member
Dear Dan
Thank you for your mesaage
I would love to see if you can of course What is the offset on those wheels
Most probably is et11 or perhaps et9.3 which could be also possible although the 9.3 were used on csl and 11 is the most common one
I have to say that the Michelin xwx 205 70 r14 also is a gorgeous tire but also a bit expensive and pretty much the same as the pirelli cn 36 which is a beautiful tire
Dan the I e who makes the trunk panel is Alprada and his name is Alvaro and yes he is also from Colombia and a friend of mine
Nonetheless your coupe is gorgeous and check out the offset on the wheels when you got a chance
Thank you
I've looked for the offset, but it isn't stamped on the rim anywhere. I'm guessing 11, but won't know for sure until I pull one and measure it.
Pirelli from Longstone are not so bad.
Yes, I'm mainly considering those. Do you have direct experience with them?
I do not have direct experience, someone posted the bought them and delivery was reasonably quick. I bought an exhaust system from the UK and it shipped quickly.
Dear
Dear Dan
Check on the back of the wheel there is a tiny round mark on each wheel where you can find the offset as pictured
Cheers and good luck
