gearbox weight
sprintevo
Anyone know how much a getrag 265 overdrive gearbox weighs - with or without the bellhousing - thanks in advance
I found those weights on: http://de.bmwfans.info/parts/catalo.../browse/manual_transmission/manual_gearbox-2/
4-speed 26.2kg / without bellhousing
5-speed sport 33.5 kg / without bellhousing
5-speed overdrive 34. kg / without bellhousing
5-speed sport 34.8 kg / with bellhousing
5-speed overdrive 34.34 kg / with bellhousing
Strong and heavy....
The far lighter ZF box, with a much nicer feel to it, was used in the Lightweight E-type.
The Getrag is the equivalent of a Kalaschnikov in my view....
Any other alternative gearboxes that could work in the E9 ??
I posted once about doing a clutch replacement in my 2002 (twice due to faulty disc springs on the rebuilt unit i had naively purchased)....the 4 speed is similar to the original IIRC in the CS and it was very uncomfortable doing the swap with that weight on my chest!
Around 85lbs seems about right.
Cheers!
Ran
someone is interested - I need a price for sending it to NZ - nothing confirmed yet, are you interested?
