My fan (9 blade viscous) is hitting the radiator under heavy braking. I've lost the tip from one of the blades and its torn up the vertical support from the middle of the radiator.
It's not surprising - i have clearance of just 5mm between the fan and radiator. My engine / gearbox mounts are all fairly new and tight.
The water pump has the bolt on adaptor for the fan clutch and there is plenty of space behind the fan. It seems this must be the problem.
Have i either fitted in incorrectly somehow, or am i able to solve this by using a water pump that doesn't require the adpator ? - i can't find anything, so any info or advice is appreciated.
