Found what we needed-WTB 2800CS Aluminum bottom covers on carbs intake manifolds-are used to preheat manifold with coolant
jjs2800cs
Need one each of these, as title says these bolt to the bottom of the Al intake manifold on zenith factory carbs. Our car is a 1970 2800cs.
Part numbers are 11611250693 and 11611257490. Engine coolant flows thru these to warm the intake manifold.
My nozzles are badly corroded and not sure they can be fixed.
jjs2800cs
jjs2800cs
I have the covers in nice shape, they were taken from a low mileage car that we did a Weber conversion. $50ea+shipping. Contact 5712862519 .I will clean these up and send more pics if you are interested. TOM BARUCH
I have fixed these with a compound called Labmetal ( from Eastwood ) I use this because after I have done the repairs, I powdercoat them usually cannot even see the repair afterwards The Labmetal is the only stuff that I have found that can take the temp of PC gets very very hard and takes sanding quite well
Thanks, Rick
jjs2800cs
Hello, I got 2 Intake manifold from 2800cs if you want it let me know
Looks like we have several options,
I am waiting for photos from a supplier and if they are not usable I will follow with these responses.
THANKS for the replies thus far.
Jeff
jjs2800cs
Thanks, Rick
We are going to powder coat the intake manifolds and these covers with high temp powder. Good to hear that the Labmetal can withstand the 400 degrees of the powder cure. Thanks
jjs2800cs
Jeff
jjs2800cs
jjs2800cs
I cleaned these up and they are really good, been off the car for 40 years. Tom
These look really good. As we said we are waiting on our usual source for parts for pictures of a set they have. If they are not is usable shape then we will contact you.
Cant thank you and others enough for responding to our request.
Have a question on looking at your pics and others I see there is a hex plug on the bottom of one of them, apparently not being used. Our piece does not have that plug, so just wondering what is is supposed to be used for?
Jeff
jjs2800cs
Jeff
jjs2800cs
It was used for a temperature switch on later cars to turn off power to the electric elements in the chokes.
Looks like my source for these is not coming thru, so PM me with what you might want for the pair. I also sent you a PM.
jjs2800cs
jjs2800cs
$50 US EACH +$20 for shipping, total $120 USD. I will ship them after I get your check and text you the tracking number. I am a 47 year e9 driver and BMWCCA MEMBER for the same # of years.
Thanks to all who have responded. Good replacement pieces have been sourced.
jjs2800cs
