The hood in my Bavaria does not stay up. In fact, there is no tension at all on the torsion springs. Can these be serviced somehow or is it a sign that the springs are broken?
I should have taken mine apart before I posted. Is it these end pieces that break?Check the end pieces. They are replaceable. The pieces that bolt onto the arms.
They can....or get worn. Make sure the system is installed correctly as well.I should have taken mine apart before I posted. Is it these end pieces that break?
You nailed it. Both ends are pretty well chewed up allowing the springs to rotate some before they start doing any good...
Yep!
The springs seem to be intact.
I'm not sure what would cause this other than 47 years of opening and closing the hood?
Greatto know...I better order some of those...a little embarrasing to have to use a redwood 1x2...
Anyone know where to ordered these??Check the end pieces. They are replaceable. The pieces that bolt onto the arms.
e9coupe.com
e9coupe.com
