Hi guys
I’m not quite there yet , but hopefully some day , I might actually get to turn the key and hear my engine running for the first time since about 1995.
So my plan is to run all new fuel pipelines and hoses
I don’t think the old lines will be clean on the inside.
So what should I do with my injectors ?
Is there somewhere that could be recommended to clean them / recondition them ??
Then I was hoping to clean out the fuel tank and line it with some form of chemical tank lining fluid.
Is that recommended ?
And then the fuel pump surge pot is probably filled with crud too , so what should I do with that , maybe it could be cleaned and lined like the fuel tank.
And then my fuel pump is probably not working either , so should I buy a new one and if so which one ( my car is a 3.0 csi )
And maybe the fuel pressure regulator needs replacement also ( maybe )
That’s a lot of questions , I know.
Any advice would be great
