They get $ 75.00 each to rebuild with new plastic.
OkayThey get $ 75.00 each to rebuild with new plastic.
Barry - don't forget to include you 007 fuel pump (assuming you still have the original) as they aren't available any longer. FIC will rebuild and test along with your injectors.Okay
That seems reasonable
Should they be put to use then soon or would they be okay for 6 months to a year waiting for other work to be completed.
I had heard somewhere before that you should not leave injectors lying around too long, but they might have been ones that were cleaned and not rebuilt.
Hi DonFIC in Tracy California sells flow matched sets of new Fj118 injectors - brand new matched is the way to go....
Cold start relay and FI relay
acquire them
Thanks for the info , did you get them flowmatched , and did they fit straight out of the box ?Hi Don
That sounds great
Thanks a million for the help
Hi Sean
I used Rockauto FJ118 injectors , cost in Feb. 2022 was $56.79 ea, new. Working fine.
Hi DonI’ll call them today for you.
They fitted without any modifications to the head / ports. I dont understand how they will be flow matched, there is no adjustment in the injector, itsThanks for the info , did you get them flowmatched , and did they fit straight out of the box ?
I read somewhere that the ports might need to be reamed out slightly to take them , but I’m not sure if that is necessary or not .
