1975 Euro CSA on BaT
Drew Gregg
Ft. Lauderdale
There hasn't been an E9 on BaT for at least 5 minutes,so here's another one with a Petri wheel wrapped with a plastic Pep Boys cover...yuck!!
The one VIN plate might be a problem for a lot of people unless someone can point him to where the other VIN locations should be, see if they are there, then snap some pics and post to BaT.
As I put on BaT, I am of the opinion that the VIN plate is original. It is just covered by butyl.
Honestly it is a period modification. I wouldn’t do it myself but I also wouldn’t critique a car for having it. Yes you can still buy them new but nobody does. It is a novelty from yesteryear and fits the car. The Petri has a painfully thin grip as did most cars of the era. I honestly think this cover looks more appropriate than a poorly executed leather recover, and most recovers are indeed poorly executed.
Hey Marcos, I tend to agree with your assessment, however I also agree with Bigmotorssmallcar in that the rivets are newer and not original, so it was off and replaced with this one (possibly the original, but there is a question of whether it is NOT original to the car, anyone can put a couple rivets through some stamped metal). In the attachment, I used a degreaser on the motor bay of my old e3 early on and wiped all my ink off of my original plate. Note the rivets are original on my attachment (much smaller and you don't see the fresh rivet break), but the placement and font of the numbers do look factory BMW on this coupe for sale. However to nitpick even more the coupe has the rivets offset, not even straight holes (one's higher than the other). And of course I had all the other VIN's stamped in engine bay firewall, steering column and original motor on the e3.
The problem is, he should easily be able to find the other VIN locations and take pics. A lot of states require at least (2) VIN locations as I did in Idaho and CA, preferably ones stamped into frame or body, not blank riveted plates that also look cut funny but could be because of the insulation. It would just make the potential new buyer that much more comfortable bidding their hard earned dollars on this car to at least fine one of the other VIN's.
Also, as Bigmotorssmallcar pointed out, I am shocked BaT let that slip through. That is the main reason for pulling auctions is questions regarding the VIN. I see it a lot on trucks like my old '75 Ford "Highboy," many people lift 2wd trucks and say they are original highboys, but once the frame VIN is photographed there is generally no more questions.
If no other VIN verification spots are photographed and uploaded, my guess is they pull this auction until further proof this is in fact the car that is being represented. I wouldn't touch it with a 10' pole until that happens.
That ad is just fabulous. Not only those tragically embarassing 70's men's fashions, but... how does Christmas increase the need to "protect" your steering wheel exactly?
I don’t think it was BigMotorSmallCar (@paul cain) that mentioned the rivets. He said the VIN was homemade. It was @Markos that believes that the VIN plate is ordinal and the rivets are replacement. I’m sure Paul agrees on the rivets however, regardless of the plate.
I agree that the firewall VIN should be included on all auctions.
The period ad is not only hilarious but waaay ahead of its time. Motor Trend: 1971 - 52 years ago.
"It's padded, perforated and the perfect gift for her. Or him. Or both of you." When did the male of our species ever come second in the advertising of the day?
Wife got her Pagoda w/that steering wheel wrap.
Seems pretty prevalent back in the day as thin rims kinda suck as far as comfort.
Wheelskins makes quality real leather covers that are first class. I have used them on a few thin rims and they look great. They make different sizes and the stitching takes an hour to install correctly. A black Wheelskins cover on this old Petri would make a big difference in the look and comfort of the rim.
Rob--Wheelskins cover will make that Pagoda wheel look and feel much better. And you will enjoy the project. Make sure all of the little leather "dots" from the leather cutout holes are brushed off the inside of the cover before you stitch it in place.
Yes sorry my bad, you mentioned the rivets but you get the gist...
