- Messages
- 402
- Reaction score
- 248
Hey folks, Don is working on this too in between some other jobs he has now, but looking to the group for relevant experience that might help me here. First, the good news, Don fixed my car in August and she's finally cured of the 12 month intermittent coil problem after lots of repairs and replacements of other parts...
Now to the AC, after a new evaporator and expansion valve that was installed by Chris this Spring, I got the R134 refill at my local repair shop a few weeks ago and they found out that while the compressor would turn on, the switch do so would not fire the compressor. After Chris' last visit and installation of the evap/expansion valve and a new AC temperature switch and some wiring upgrades, it turns on the new AC temp switch is receiving power but not sending it to the compressor.
Don has sent me a new AC temp switch that I have yet to install but a new problem has surfaced...
After trying to diagnose the problem with the aftermarket AC temp switch, I subsituted my old OEM switch and found some electrical shorting at the spade connnectors when I did that; thereafter, the AC switch would not fire up the AC evaporator fan in the console whereas it was working prior to the shorting episode.
I've looked all the way to the fuse box and the green/blue wire coming out of the fuse block and the connections are good and I get 12V at the upper and lower portions of the #8 fuse. So the problem appears to be between the fuse box and the AC fan switch which is not showing any 12V power. The wiring diagram shows a straight path between the fuse box and the AC fan switch. Per Don, I removed the electrical connector to that AC fan switch and tested for voltage at each of the three connectors inside, but no power. So the switch is probably okay?
A very weird problem that I'll get more ideas from Don next week, but hoping someone here might have had a similar experience that I've not looked at yet...
Thanks in advance, all!
