Howdy All,
I have a customer looking for a small red screwdriver (imagine that) anyway I pulled out a few I have and now I am wondering what was delivered from the factory.
I have 4 small red drivers and I will try to describe them the best I can:
#1 This one is the darkest red of the four, it says made in W. Germany in small font on one side the other side is blank. The "clip" that hold the driver shaft in the handle is made of two metal clips and the lowest portion of the red plastic is knotched the same as the handel itself. By the looks and construction it appears to be the oldest but that is just a guess.
#2 This one is the second darkest red, it has a "2" one one side as well as Heyco but the 2 is rotated 90 degrees and would be read verticle where the "heyco" is horizontal. The flip side says in small font Made in W. Germany. The "clip" is black plastic and and hexagon shaped and pressed into the end of the red plastic. The bottom portion is smooth and not knotched as the first one.
#3 and #4 Are basically the same on one side it says "DGBM" on both running horizontally and vertically one has a "2" the other has a "3" on the flip side the both say made in W. Germany. The clip to hold the driver is is also a hexagon shape and pressed into the plastic but it is pink in color.
Big Red screwdrivers
#1 This one says CHR-VAN and right below that says made in W. Germany, these are the only markings on this one.
#2 This one says Heyco on the handel the flip side say made in Western Germany-10000V. THe driver shaft says CHROM-Vanadium 1,0x7,0. The tip is also machined about 3 mm and it appears to be factory as there are cross hatches and it is just a tad bit thinner than the rest of the tip.
Sorry the pictures are kind of bad but hopefully you can see some of the details.
