E9 Csi ECU
Georgie22
Commugny, Switzerland
Hi everyone, I have a 1972 BMW 3.0 CSi VIN 2262612
I have an issue with the ECU it seems, do you now where I can get this repaired by someone competent.
I am based in Switzerland.
Pretty rare for those to go bad. Have you tried borrowing a spare?
What symptom makes you think the ecu is bad?
one of the injectors is not working and thus runs on 5 cylinders. Garage cleaned the injectors and said it was the ECU that was defective.
Any idea what else it could be?
I don't know anyone with a spare. Here in Switzerland these cars are not very popular
If it is 1,2,3 or 4 they are likely wrong.
The e9 forum has a djet loaning library.
You pay shipping and we loan the part.
We have Ecu’s to loan out.
As fare as I know,
There are 3 cylinder are triggered together by the ECU ?
Check for broken wires from the ECU to injectors.
If not, maybe only a cold weld in the ECU.
@sfdon Already post the diagram.
Breiti
The garage didn’t need to clean the injectors to say the computer is bad…
Every shop should have a Noid light tester.
I think 2 drivers and 4 connectors at ecu.
Very unusual.
Firing 2 banks of 3 but using single wires to 5 and 6.
Name
address
phone
email
send me a PM by clicking on the sfdon icon.
I will send out a test ecu.
I’m in Amsterdam, Paris and Malaga next month- no Zurich…. Otherwise I could deliver. :)
Check this side
Cylinder 1, 3, 5 and 2, 4, 6 have each a commen driver.
So if the electronic will be bad, you have 3 valves not working.
The rest is wiring outside the ECU or
a conductor path , a connector or a bad weld in the ECU.
Good luck
Breiti
SFDon’s lending library of Djet parts is a life-saver for CSI owners, as is, of course, his knowledge. Get to know him, he is an invaluable resource.
