Clutch house rooting questions
Breiti
Mainz Germany
As some of you know, I switch from automatic to 4 speeds shift.
Got a late trans with closed bell housing getrag.
The question is, how is the "break line" and the hose between clutch cylinders are rooted?
Think, I need a hose like this 21521116422 ?
And what else?
Pics how installed?
Thx for your help
Breiti
The clutch metal pipe on my RHD goes across the bulkhead along with the brake pipes.
then down on the left hand side of the trans tunnel, then joins a flex hose to connect to the slave cylinder.
Sorry I don’t have pictures at the moment.
I took some pictures prior to disassembly, but they do not show the master or slave cylinder fully. You can see the fluid pipe that transits from the master through a guide bracket. What is shown is for a 1972 with original 4 speed manual transmission. If installing a 5 speed (which am doing), then a longer hose will need to be sourced.
thx for the Pics, but is that a closed Bellhousing? it seams like it is a open?
I look for the late version with closed bellhousing.
Breiti
In my shop we use the '74 slave, the e12 master from RM european and La Jolla Independent stainless hose.
175.00 for all three......
Clutch Slave Cylinder
$18.46
Part Number: 21521157212
Part fits: 1980 BMW 528i Base Sedan E12 2.8L L6
Clutch Master Cylinder
$51.60
Quantity:
Question?
Part Number: 21521156004
$51.60
And what else?
Pics how installed?
Thx for your help
Breiti
me have some
I must ask again, has anybody a pic, how the bracket for the clutch hose is installed at the closed bell getrag please?
Thx.
Breiti
Hi. I did the bracket with a hard line to a flexible hose on my E3.
I do have the closed clutch housing.
