Flasher relay 1 364 654 for 3.0CS
ChrisMc
New Member
CT
Hi All,
I’m relatively new to the forum. I’ve seen some great threads and advice.
I’ve got a 73/4 3.0CS which is running well except for turn signals failed. We traced to the relay (reference # above) and pic attached. Any ideas on where I cud obtain one? Napa didn’t seem to carry a FFF unit.
Thank you,
Chris Mc
Hi All,
Thank you,
Chris Mc
Your original relay may be serviceable by careful disassembly and cleaning contacts, including moveable points. Your vehicle's hazard "flasher" switch may or may not have some bearing on turn signal operation. It still is a good idea to check all related grounds/connections, then peruse the linked posts. ;)
1626701012611-png.123197
https://e9coupe.com/forum/threads/flasher-relay.6507/
https://e9coupe.com/forum/threads/yet-another-flasher-thread.38392/
https://e9coupe.com/forum/threads/flasher-relay-fix.40029/
http://www.e9-forum.de/viewtopic.php?f=16&t=25976
Tochi,
Thanks for your valuable input. The relay had copper terminal that had broken off and rattled when removed. So I’m looking for a replacement. Already have replaced the flasher switch so hopefully new relay fixes the issue. Only concern was wire (green/cyan) was quite warm when removing relay. There may have been a shorting issue because of broken relay. Currently taped and isolated til replacement part is installed. Thanks.
