Grease recommendation for transmission input shaft and release bearing grease.
boonies
Car's aren't the problem, storage is...
US - Philadelphia suburbs
I was reading the blue book for a later BMW 6 series (matches the 5 speed) and realized that I don't have the Molykote long-term grease that is called for to lubricate the release bearing or the input / clutch disk splines.
I am not opposed to buying the Molykote ($$$), but is there a reasonable substitute that you can recommend? I think the key is that the grease needs to hold up under heat so that it wont migrate to the clutch disk.
Mo S2
Molibdenum disulphur
lots of greases, some much better than molykote, i.e. quaker,...and so on
high MoS2 good
