Anyone else have trouble reinstalling the under dash panel?
Bmachine
Northern California coast
For some reason as I try to reinstall the panel under the steering column, the right side hits the square heater exhaust unit. The left 2 screws (one near the firewall and the other right above the green button on the pic) fit just fine. The problem is just on the right side.
I already trimmed the foam part of it but I have reached the metal framing inside the foam which will require more serious alteration. It is still sticking at least 1cm too far out
(Note that I have indeed tried with it above that metal "pin" and with the brown wires pushed out of the way)
It's hitting this section here:
I'm not sure how it was before since that it was many years ago that I removed it.
Has anyone else had this issue?
I might add that the heater box was rebuilt and reinstalled but I don’t see how it could have moved since it is bolted onto the firewall.
so did the Dynamat turn vertical on the inside of the firewall? curious if that could have pushed the heater box into the car a bit
The Dynamat suggestion seems like a good candidate to check.
If that route doesn't solve it, then perhaps the panel itself was deformed during storage? After all it is a foam over steel plate construction , where the steel has an almost flat section (no strengthening ribs), thus easy to bend.
Good thinking on both counts, guys, thank you. But the Dynamat was installed long after the heater box was so it does not play a role in this case
This panel's shape could indeed have been deformed during storage. Although I don't see how it would have affected its length on just one side by more than a centimeter.
Since this is obviously not a very visible area, I suppose I could just cut a piece of that panel off until it fits. I just don't like to fix a problem without knowing what caused it to begin with
It's almost as if either a) the shape of the heater box had changed during its refurbishment (did its shape change at some point during model years?) or b) the whole unit is not flush against the firewall. But that would seem to be difficult to achieve since it is attached to 4 existing studs welded around the square opening for the fan. On top of that it would have affected the position of several elements of the center console.
Just cutting the panel untill it fits isn't a beautiful solution (which is just my personal opinion); I hope we can can come up with some better solutions for you.
(I don't even see how it would make a difference just yet, but let me ask some questions, perhaps somelse will have a bright idea from these thoughts: )
- I see you have AC, was that also prior to your rebuild?
- Is it the same heater box that was in the car before? If so, then it should fit and something is amiss.
- Deformation could possibly make the panel just fit above the outlet of the heater box, but that's just guessing from the pictures.
Can anyone with an intact car & panel post a pic of how it's supposed to be (or at least how it fits in their car?) My car is in pieces....
I've never heard that there are different shapes of heater boxes over the various model years. Although Realoem does show a 5 versions:
interesting dilemma!
I would hold off on installation until you have the center console in place, you may not need to have this as far forward as you believe you should.
Yes. Nothing was modified under there apart from being cleaned and rebuilt
Yes, it should be. The heater core was rebuilt by a radiator shop. Then the whole box was cleaned with new seals installed. It is hypothetically possible that the person who rebuilt it happened to have another one there and accidentally swapped it but that would be very unlikely. Although not theoretically impossible
Right above that hard plastic of the heater outlet is the flex tube that goes to the windshield defrost. And that sits in the same vertical plane so even if the cover panel could be moved further up, it wouldn't really make any difference
Yes. You expect a few fitting issues when reassembling a 50-year-old car. But this is about 1.5 cm off which is more than just old parts that need to be convinced to play nice with each other
At this point the only thing that would make sense is the idea that I accidentally received a slightly different heater box from the guy who rebuilt it. But that seems pretty unlikely. I will have to try and contact him
The center console and everything else under there is already reinstalled. The only thing I have temporarily taken off is the hard plastic cover under the steering column just to see if that would make any difference
I'd look to see how mine is but I don't feel like getting under the dash. Sorry.
What is the problem there? Yes, I was tossing and turning all through the night with my knees and my neck hurting, but, apart from that…
Sorry, I was looking at the images you presented. I am gonna go and look at mine today and see what's what.
Double check how the wiring is routed behind the panel. A wiring loom that is out of place could push the panel into the heater exhaust unit.
Oh wow. Super interesting @Erik . So it looks like you have loads of space between the cover panel and the heater box. While mine crashes into it and that is still not enough! What year is your car? And do you have a wider view of the whole installed cover panel by any chance? Something like this maybe:
Thanks very much for diving under there and taking these! I know it is a bit of a pain. Even @dang wouldn't do it. ;)
Don't know if these will be of much additional help & they're all somewhat similar. It is interesting to be reminded of how weak the design was for the attachment points of some of the interior items that were designed for the coupe.
This under-dash piece is not in the best shape, but does seem to fit snugly directly below the dash (within '70's era margins) and it does sit off the box below. What seems odd and unsatisfactory is the nearly 1"+ gap below the adjustable steering column cover. Seems like it should be adjusted to fit better, but not sure how, given other clearances. Maybe that's what would motivate some trimming off the rear?
Maybe the '74 piece is a hold-over from the original, previous iteration and does not sync up with the later steering column cover well. - Don't have an earlier piece to compare to. Maybe some of our seasoned parts-hoarders would know?
Super helpful Erik. Thank you!
It seems like yours “droops” a bit in the middle which makes it contact the lower part of the heater box. While mine is flatter and touches the upper part of it. That could actually make an appreciable difference. And it would fit @eriknetherlands hypothesis of deformation during storage. I won’t be able to test that until Sunday but I am anxious to see if I can bend mine a little bit in the middle like yours
It seems like the panel ought to sit behind the column cover so that the cover would support the panel. (?)
Did you install new or recovered side panels to your hvac ?
