“Sorting” the Rebuild - ‘69 2800 CS #2200561
Dave G
CO
I am 10 years into the bare metal restoration of my coupe and am excited to finally be at the stage of building it back up now that the rust repair, bodywork, paint and engine rebuild are complete! The front and rear suspension are in. All that’s left is the restoration, sourcing, installation, and debugging of the other thousand parts that need to go back on! I hope this thread will be a good way to document common issues and solutions for “sorting out” a rebuild.
Issue #1: Braking system is unable to hold a firm brake pedal. Prior to this, I rebuilt the brake master cylinder with new seals. Front calipers were sent out to PMB performance to be cleaned, blasted and yellow zinc plated. I assembled them with all new seals and bolts. Rear drum brakes got all new parts including new rear brake cylinder actuators from Walloth & Nesch. All brake lines, hard and soft, are new. The rear brake regulator/compensator is original. I filled the brake reservoir with new ATE type 200 DOT 4 brake fluid and began bleeding from far to near the master cylinder, starting at the back right wheel and proceeded to do all four wheels using a vacuum bleeder at the brakes. Break pedal still soft. Repeated bleeding process and lots of bubbles still coming from the back brakes. Soft pedal still. Since the bubbles could be coming through the loose threads of the nipples while vacuum bleeding, I decided to switch to pumping the brake pedal three times until it got firmer and then held it down with a piece of wood cut to the needed length (27.875”) between the depressed pedal and the driver seat support box on the floor of the chassis. I also checked and tightened every brake line connection on the car and found no apparent leaks in the calipers, lines, rear compensator or master cylinder. Bled all four wheels two more times until bubbles were gone but the brake pedal was still soft. When pumping the brake pedal, gushing/wooshing/squealing sounds can be heard coming from the front and back of the car. I used a video to see that the back brakes were actuating and a stick to push on the front wheel studs to test that the front driver side brake was working when the brake pedal was depressed. When pumping the brakes, the pedal gets firm near the bottom of the third stroke. But if I pause for a few seconds at the top of the third stroke, it will be soft and go to the floor on the next stroke.
I suspect it’s due to faulty sealing points in the master brake cylinder, particularly when the piston is near the top of the stroke. Perhaps there are imperfections in the cylinder walls allowing fluid to leak past the seals on the piston? I am hoping that a new master cylinder will resolve the soft pedal. Thoughts?
#2: There is a small seepage of brake fluid coming from most of the eight bleed nipples on the car. All the nipples are new except the two top front nipples where I cleaned up and reused the older shorter nipples. I’ve read online it may take a few open and close cycles to seat the nipples but I’ve done that now and still have seepage from all but the two lower nipples on one front caliper. I don’t dare tighten them any harder. I presume this may only be a small amount happening during the pedal depression which is generating hundreds of psi in the brake lines and it may not necessarily be allowing air back into the system when the pedal forces are removed. I’m not sure how concerned to be about this or if it’s worth pursuing further options like new calipers and rear cylinders, softer nipples, reworking the nipple shut off surfaces in the calipers, teflon tape on the nipple threads…?
#3: ATE type 200 brake fluid currently used is DOT 4 classified and labeled for racing. I like the idea of a non-hygroscopic fluid like DOT 5 that would not absorb water. Any known documented reasons not to use a more modern DOT 5 product?
Thanks in advance for sharing your experience and knowledge.
Dot 3&4 are not compatible with 5 so once in your system you should stay with the former. 5 isn’t necessary in these cars unless you’re racing at Laguna Seca.
Are you using factory bleed screws from BMW?
Not using BMW factory bleed screws, I will give that a try, thanks Steve
DON'T use silicone DOT 5. Unfortunately been there, with horrible results. Maybe for museum cars.
There is a different DOT 5.1
Overtightening bleeders can distort them, partially collapsing the cone and the small side hole.
As Stevehose suggests, try new bleeders first.
The seepage in the bleed fittings is a telltale. It doesn't take much for hte pedal to fall to the floor when there are hundreds of PSI created by relatively little fluid. So I'd definitely change to OEM fittings, and see of that alonne has an effect. There should be NO fluid leaking anywhere.
If the pedal still goes to the flor an there are no wheel caliper leaks, then the issue is your MC.
Didn't we have a thread recently where the problem was the length/adjustment of the MC rod or something like that?
no teflon on the bleed nipples
No DOT5, use DOT4, Typ 200 ATE is the one i use, good !
Yes, thanks, I did see several posts where the .5 MM gap between the MC shaft and the brake booster shaft was missing, causing the brakes to drag and heat. Hopefully not my issue also since it’s a blind connection and hard to determine without the tool that I don’t have that was shared in the thread!
A quick follow up to the issues above
1. Soft break pedal - I went ahead and sourced and installed a new master brake cylinder and it also had the soft pedal issue of the original rebuilt cylinder. Then realizing it may have to do with the rear brake drum not being installed over the shoes. After I did that, the pedal became firm! Lesson learned.
2. Brake bleed screws oozing - I ordered BMW ATE screws and OEM FTE screws and tried them both. Still getting a slight amount of oozing. I’m assuming there may be some issues with my rebuilt and newly yellow zinc plated calipers. They are so pretty, it makes me sad to think it was for nothing. I went ahead and sourced a new set of front calipers from WN and I will wait to see if I have continued issues with the old rebuilt calipers before changing them out.
I think new calipers are a good idea.
They are your brakes after all.
Just having calipers rezinced wouldn't be the reason for leaky bleed screw threads. The electroplating adds a layer that is very, very thin. + zinc is quite soft, so it deforms, like copper , and would even seal a teeny bit slightly because of that effect.
If anything, it would be tighter, not more loose.
My guess is they were treated badly before (over tightening / wrong threads / rusted). Plus the bleed screws that you removed may have been glue tight/ shut.
Not sure if that was the case ofcourse, but today one couldn't see it anymore as such possible glue would have disappeared mostly with the bleed screws pulled out. Any remainder of glue would have been etched out by the acid bath of the plating process.
Do not use PMB provided bleed screws- they are the wrong shape.
Only original.
agree, they didn't even provide them when they rebuilt mine, sent them separately when I asked, then I threw them away and bought BMW ones.
Startup
Finally ready to fire it up for the 1st time since completing the M30B35 donor engine rebuild and installation. My friend, Keith, came over, we filled it with SAE 30 Lucas break-in oil, power steering fluid and finally a mix of Prestone Coolant Flush and water to get any final particulate out after the block boiling/deck milling/rebuild and head milling/valve job/cam and rockers replacement before putting “normal” coolant in. That's where Murphy joined us... Keith, while adding the water, asked, "Does this hold more than 12 quarts? Because I'm on the 4th gallon of water and it's not full". I thought maybe he miscounted, stopped what I was doing and watched and listened to the water going into the reservoir. Then I heard what sounded like gurgling coming from the oil cap opening on the valve cover! The discomfort set in. Checking the dipstick revealed what looked like water with the oil. We drained the oil pan – water gushed out followed by oil! We went through all the failure modes we could imagine while I entered a state of anger and depression. I let Keith go home and I went inside to sulk! After I came to better terms with the situation, I went back out to the car to blow compressed air into the coolant lines to see if I could find where it was coming out. Air came right out the oil sensor port (sensor removed) at the back of the head and out the oil fill opening in the valve cover. I pulled the valve cover to have a look and blew more air into the coolant line creating a water geyser from the middle top of the head, under the camshaft, where a large plug was supposed to be! Keith soon sent over the exploded view of the 1992 M30B35 head showing 2 coolant plugs, 22mm each. The one in the top of the head, under the cam shaft, immediately caught my eye. Mystery solved. When the head was sent to be re-built, the plug was there, when it came back, not so much! I got a stainless M22x1.5 plug from Belmetric that I was unable to get started in the hole and the BMW plug is on the way. Keith & I have been thinking of different ways to install the plug under the cam without pulling it all apart. Our best running option is to cut off a short section of a hex allen wrench and insert it into the top of the plug (Belmetric is 10mm hex) and then bend a cheap flat sheetmetal stamped “disposable” 10mm wrench to fit under the cam and onto the stub of hex sticking out from the plug to tighten it. More to come after the BMW plug arrives…
5 spd transmission alignment. Hello. There were two other important lessons learned after my last post that I will save for another time, however, my current issue is alignment of the driveshaft and transmission. I finally got the Getrag 265/5 five speed OD transmission and bell-housing installed. I had my driveshaft shortened by 4 inches to leave a tiny bit of wiggle room over the 3.875 inches of length the five speed transmission adds by my various measurements. When I connect the driveshaft to the transmission, the driveshaft is coming in about 1.5 inches too high at the center bearing mount point when it comes straight off the back of the transmission without flexing the Guibo coupling to point it more downwards. Realizing it needs to be straight, I am wondering how others are supporting the Getrag 265/5. I used the cross brace that came with the 1979/80 dated transmission. I connected it to the supporting fork on the right side of the transmission, photo attached. The transmission also has a fork on the left side that is about one to 2 inches higher up than the right side and a third fork at the back where my car has no brackets to support it. I used the standard rubber/steel transmission support/mount. I haven’t compared the 1979 crossbrace closely with my 1969 cross brace but my impression is that there may be some differences in dimensions. It appears that I need to lower the transmission about .75 inches in order to get the driveshaft to line up with the center support bearing. However it appears that I only have about .5 inches of clearance between the cross brace and the bottom of the transmission and of course the rubber mount is not adjustable in height. What am I missing? Thanks!
Also related to the above question, what are people doing to support the tail end of the gear selector mounting plate in the E9 5-speed conversions. see photo. I used a long sheet metal screw and a long steel bushing to hold mine temporarily for now. I see some brackets on the E 24s and E 12s that were used on those cars but not sure what the best option is that folks are going with for the E9 coupes.
with regard to the Getrag support:
one option is this: the 5spd tranny support made by Coupe king:
for support to the tunnel the original ( I think ) solution is this (the 2 brackets are there to load the rubber in compression, not pulling. This way, if the rubber fails, the tranny hangs on the bracket):
Don's recommendation:
A bolt, 2 washers, a swaybar rubber donut and a nylock…. All done.
other option is a brace, as it also included in Coupe King's solution:
Thank you Erik, this is great. I appreciate your help!
