Tool Kit - OK so what am I missing?
You don’t have sardine can motors
Oh thanks Chris, learn something new from you every day. I didn't realize there was a change in the electric window motors, did it happen in '74? I was also scratching my head as to why I didn't notice the cap that needed to be removed in order to use the comb, just figured I didn't look hard enough. Now that explains. that. My right rear was just regreased and working amazing, then all of a sudden decided to stop working, it is up at least. It's an electrical I think (so it will turn out to be mechanical), it is only the one passenger side rear window. Not sure if I shorted something when I decided to plug in the lighter to see if it worked (right below the window switch), too much of a coincidence, hopefully just loose wire under there. Will be looking into this now along with the headlights next week. Always something with these ol' gals. I'll check the fuses of course first, later today, but I don't think it would be that or two windows wouldn't work.
Valve adjusting tool which I have $14.50 shipped
