Todds Coupe
OK, the manifold port on carb 1 is connected to the brake booster. I have the distributor vacuum line connected to the manifold port on carb 2. Am I understanding this to be correct?
read through my posts again - distributor needs to be on ported vacuum, not manifold vacuum.OK, the manifold port on carb 1 is connected to the brake booster. I have the distributor vacuum line connected to the manifold port on carb 2. Am I understanding this to be correct?
Steve, I'll try that as well. The distributor needs vacuum, yes? You are suggesting that I connect it to a ported vacuum rather than the manifold vacuum. I'll find one and connect that and see if it changes anything. I have differing replies in this regard but I am open to suggestions. Some say the distributor should be connected to the manifold, where I have it now. My mechanic is away for a week, when he gets back we can hook up the O2 sensor and try. Thanks again!!read through my posts again - distributor needs to be on ported vacuum, not manifold vacuum.
Manifold vacuum can be used effectively for a distributor, but for the stock E9 setup, as has been mentioned, ported vacuum should be used. Using manifold requires a different advance curve, idle settings, etc. I use manifold vacuum for my setup, but I have an electronically adjustable distributor curve. For your stock engine, try not to get caught up in internet/mechanic debates on manifold vs ported vaccum for advance.Steve, I'll try that as well. The distributor needs vacuum, yes? You are suggesting that I connect it to a ported vacuum rather than the manifold vacuum. I'll find one and connect that and see if it changes anything. I have differing replies in this regard but I am open to suggestions. Some say the distributor should be connected to the manifold, where I have it now. My mechanic is away for a week, when he gets back we can hook up the O2 sensor and try. Thanks again!!
