First post. This forum has been a valuable resource over past months. Much appreciation and many thanks in advance for the following questions.
Background:
Putting back together an E9 CSL that was completely gutted for a bare shell respray. Disassembly was 3 years ago, and not carried out by myself. Last time the engine/drivetrain ran was 3 years ago.
Am not sure whether the problem is the Distributor Contact Trigger, ECU, MAP, or something else?
- Really hope it's not the ECU.
Diagnosis so far, what have I missed?
Thank you!
Engine turns over.
Verified spark and fuel pressure (set at 28lbs).
Fuel injectors are not receiving voltage, verified by NOID test light. The NOID lights up for a single temporary flash on Inj 2 & 4 when providing switched power (is that normal?).
- Test light triggered for duration of 1-2 seconds, once during cranking, but was unable to repeat this result at any other time during testing.
MAP (This unit has been modified by the engine rebuilder to be adjustable)
Resistance on Pin# 8 to 10 & 7 to15, verified.
Continuity to ECU pins, verified.
Voltage test to be conducted...
- Tried searching, is there a good link with MAP voltage testing instructions?
Distributor Trigger Contact
- Distributor Trigger wires output to the ECU pins # 21, 12,. 22 continuity verified. Is this the correct sequence, facing the connector on the housing, from left to right, #12 in the middle?
- Distributor trigger: Is there anyway to test the signal?
ECU
Pin #
11 - ECU ground verified
16 - Power to ECU verified
24 - Power for injectors 12V verified
Inj. harness
Injector grounds and connector continuity to Pin# 3, 4, 5, 6 verified
Injector Grouping verified
TPS
Pin # 17, 20, 9 continuity & ground on 45 verified
Injection System Wiring Diagram
Source: https://e9coupe.com/forum/threads/d-jetronic-rebuild.18687/page-4
D-Jet ECU Pinout
Source: https://jetronic.org/en/d-jetronic/pinout#bmw
Background:
Engine turns over.
ECU
Pin #
Inj. harness
TPS
D-Jet ECU Pinout
