Heater cable clamp
Rod Cole
Maine
The heater doesn't work, and hasn't for a couple years. The temp. control on the dash doesn't slide left and right due to the clamp at the end of the cable not snapping into the bracket. The clamp itself looks fine but will not stay in place (lock on) so I want a new one. Issue is, I can't find one and hope a part number, or other info gained from this post will help. I will put up some photos of the part I need, sure hope someone knows how to get one~
I picked some up a few years ago and they show on Maxamillian as still available.
Part #64 111 351 375, Item #9 in the image below
Having trouble with the Maxmillian web-site, they do seem to have the part but I can't get the order form finished. It wants a shipping method but no place to check off a method or anything else~
....sure I have one, 5€ plus shipping in an envelope to your place. Anyhow, let's try to figure out first why your's is not staying in place. Might need some bending somewhere?
I think if it were in a more friendly work location & if I didn't have bi-focal vision aids I might be able to get it to stay. That said I got the others without any issues
Looks like Pelican Parts has it also, but no photo, however it has the right part number so I think it's right. If Max doesn't get back I'll get one from Pelican
Yes, I had that issue with their site as well. I sent an email to their customer service department, detailing what parts I needed, and they replied promptly. When I did this a few weeks ago, I was informed that most of the parts I needed were not in stock, so I didn't end up placing an order. Consequently, I can't explain how to complete an order using their faulty website (perhaps by phone).
I was thinking the same thing; it's a basic part, with a pin (hook) on one end and a snaplock on the other side. The cable runs under it, being pressed down. The 'floating' lip in the middle of the clamp has 2 teeth that bite into the cable, preventing it (if all is well) to slide back and forth.
These parts are all present in the pic you share, so it leeds me to believe your part may be deformed, or the cable is (locally?) thinner.
As a simple solution; would it not help if you put one or more zip-tie(s) around the cable, e.g. one just next to the teeth, and one on either side of the clamp?
Possibly even another, running under the cable, and crossing over the teeth?
As there are 8 of these clamps on the heater control mechanism; (one on either side of the cable, 4 cables).
Does the problem 'move' if you switch 2 clamps? This test would confirm if the problem indeed lies in the clamp - possibly it could be loose on the other side as well.
You also mention that the clip itself doesn't stay in place: from that i understand that it rotates (a bit) around the pin of the clips that dives into the hole. Is the other end actually correctly snapped in place?
It should look like this: in this pic we are looking at the snap side of the clip.
See how the straight edge of the clip bites into the underside of the base plate?
Don't be confused by the black cable that runs in front of the clip; that belongs to another clip. The clip holds the cable that is just behind it, peeping out on the left side of the pic.
From the above picture I can see mine is too long. If I have the hook end that goes thru the hole pulled down so that the 90 degree bend is right against the edge of the hole (as above) the other end (the snap end) is too long to even touch, but only a hair too long. I think it's just been pulled a little too hard too long.
I got a package in the mail today & now the heater is working. I had called La Jolla and told him I couldn't find the clamp, he said he didn't have a new one but could find one in his used parts stash. Not hearing back I figured he had none or forgot, so I posted here, tried Maxamillion and WALLOTHNESCH who are both without any, so thought I had to do some cobbing with jb weld or tie wire! Looks like I got lucky, now I only need to pay a bill! By the way, the clip looks new!!!
Good to read that you've managed to solve it.
Indeed these clips don't really suffer being in the interior. Also, I think the original plating is Cadmium based, so really rust resistant.
Like many other e9 nuts and bolts.
And toxic if one decides to sandblast them....
