Official thread of parts for sale w/ridiculous prices?
Thanks for this info. I know there are a lot of steps and strong chemicals involved but it might be a satisfying winter project. Not this winter as I'm packing to move back to Austin this spring. My tools are pretty rough, but I'll keep them with the car as they have been for the last 53 years. Just not in the tool tray though... View attachment 196678
Check out my case here:
Erik opened my eyes to that stuff possibly being foam decomposing and not corrosion. Worth a shot.
Sometimes RUST911 or even vinegar (or other chemistry) can remove surface rust well enough. Than some wax or oil be used to protect against oxidation.
An example: citric acid it not eating the chrome (but zinc plating).
As some have mentioned, the best way to protect tools (and the tool tray) is to keep them at home under the blanket.
Yes, I've had good results with the acid-free, water-based rust removers that draw the rust away or lift it from the metal. This process is generally accomplished through chelation. There are commercial brands such as Evapo-Rust, but also less expensive versions from Amazon or ebay that work just as well. Once done, the process also tends to protect the steel for a while. It does turn clean steel a bit dark, but for most things, that doesn't matter. I'll have to pull the tools out of storage to closely examine their condition but that will have to wait until after my move to Austin. For protecting tools that I've derusted, I've been very happy with Boeshield T-9. It leaves a coating of wax-like substance that doesn't transfer and is long lasting. Not cheap, but a little goes a long way. However, OEM BMW tools should be chromed, for originality and longevity, if possible.
For public entertainment: I rather suspect this is a typo - anyone interested in a BAVARIA shield?
sp when did a 'new' Nardi 360 wheel get so expensive? its got the new style hub and its 1600 bucks? ... and $155 shipping
and even more ridiculous - $4950 for so-so wheels and bad tires. and local pick up ONLYView attachment 202969
funny, i just reopened this thread and i see that this post that i made is the same ebay post that @teahead used to start this post ... same price that hasn't been reduced in all this time - march 2023 ... so over 2 years !!! still for sale at same price
Today's addition: changed the oil and filter on the 3.0S today. Still has the original cartridge filter so I change it by removing the whole assembly from the block. Thought I had a couple of spare gaskets for between the block and the bracket but couldn't find them. RealOEM shows them for $2 each. I know those prices are obsolete but I was not prepared for $25 EACH from my local dealer. Four in the Jacksonville warehouse. At that price, I ordered two before they go up to $100. I assumed this price must include installation, filter and new oil but the parts guy just smiled and apologized.
I live in a smaller city that probably is a minimum to be able to support our own dealer. I take some satisfaction in helping to keep him open.
Don
Don
Yikes! At those prices I'd be very tempted to buy some gasket stock and use the OEM ones as a template. They aren't visible (much) when installed.
