How difficult is it to add original AC(with all the new upgrades) to a stock 3.0CS? Availability of part? Ball park figure if a worthy shop does the job?
Thanks,
Steve
Thanks,
Steve
I think $12kI’ll play. Assuming you can find usable interior parts that are expensive when you do, my guess for a shop to do it per oem design including parts and labor would be $10k.
I'm interested in this subject as well. I have the original parts, even the muffler. I am wondering if a new, modern compressor requires a different bracket and if replacing the 1973 condenser with modern, parallel flow would be advisable. I've done all this on Volvos, but have a CS that I want to put the AC back into.How difficult is it to add original AC(with all the new upgrades) to a stock 3.0CS? Availability of part? Ball park figure if a worthy shop does the job?
Thanks,
Steve
Jim - PM me for details - the answer to your questions isI'm interested in this subject as well. I have the original parts, even the muffler. I am wondering if a new, modern compressor requires a different bracket and if replacing the 1973 condenser with modern, parallel flow would be advisable. I've done all this on Volvos, but have a CS that I want to put the AC back into.
@HB Chris, thank you. Where do I find the correct brackets for the Sanden?And in an update you will need a new drier and ditch the muffler which was only used with the old style compressors (besides you will be using new fittings).
I know for a fact that SD709 is for R134a (I have used on 2 cars) and believe that SD508 is also.Thanks for the replies, will follow up. PS: I found this great post, but unfortunately all the pictures are no longer available.
One more question if I may: why are folks here apparently preferring old Sanden compressors like the SD508 and SD709 that are designed for R-12 refrigerant over newer models like the SD7H14 or the SDH14 that are designed for modern R134a refrigerant?
I've been on this same road for a very long time, slowly acquiring parts when the opportunity arises. Like others have said, the tricky part here is the interior bits. Just for the interior, you need:
1. complete evap assembly (blower motor, evap core, blower resistor, etc)
2. new center consoles with the holes cut out (thanks, Alberto!)
3. covers for those holes (several people make them now, including me)
4. the intermediate duct (I made my own design for that based on the original part, Don seems to like them!)
5. the metal base plate
6. the AC faceplate
7. the switchgear
Everything other than #1 is unique to the coupe as I recall. A very long time ago, I bought a set of the parts for a Bav for ~$200 and I've been building most of the E9-specific parts myself, as they are ridiculously expensive. Plus, if you have a radio, you'll likely have to modify the AC faceplate, as that's where the radio goes. You also lose the really nice wood cubby under the heater controls.
Going through all this has made me work on making a combo kit using the original space of the base heater box, and instead turn the system to a combo unit like on other modern vehicles. Given how my day job is going, though, that is a long way out.
