Adding AC to a Coupe
CSteve
Bucks County, PA
How difficult is it to add original AC(with all the new upgrades) to a stock 3.0CS? Availability of part? Ball park figure if a worthy shop does the job?
Thanks,
Steve
I’ll play. Assuming you can find usable interior parts that are expensive when you do, my guess for a shop to do it per oem design including parts and labor would be $10k.
Another question, and I am sure there will be more. Do any of the aftermarket systems work effectively. and leave the console basically stock? Thinking of units I have seen with the ducts on the parcel shelf.
Steve - I will contact you via PM. I would think that an A/C retrofit can be done on a smaller budget, using aftermarket parts and 3D-printed parts. This assumes you are able to do most of the work (+ sourcing of parts) on your own. Asking a shop to do everything would be an entirely different matter.
Thanks,
Steve
I'm interested in this subject as well. I have the original parts, even the muffler. I am wondering if a new, modern compressor requires a different bracket and if replacing the 1973 condenser with modern, parallel flow would be advisable. I've done all this on Volvos, but have a CS that I want to put the AC back into.
  • Like
Reactions: Dlc
Jim - PM me for details - the answer to your questions is
-yes - the Sanden is better and requires a different bracket (2 in fact)
-yes - the parallel flow condenser is cheap and performs much better with R134a
Post #2 here:
I've been on this same road for a very long time, slowly acquiring parts when the opportunity arises. Like others have said, the tricky part here is the interior bits. Just for the interior, you need:
1. complete evap assembly (blower motor, evap core, blower resistor, etc)
2. new center consoles with the holes cut out (thanks, Alberto!)
3. covers for those holes (several people make them now, including me)
4. the intermediate duct (I made my own design for that based on the original part, Don seems to like them!)
5. the metal base plate
6. the AC faceplate
7. the switchgear
Everything other than #1 is unique to the coupe as I recall. A very long time ago, I bought a set of the parts for a Bav for ~$200 and I've been building most of the E9-specific parts myself, as they are ridiculously expensive. Plus, if you have a radio, you'll likely have to modify the AC faceplate, as that's where the radio goes. You also lose the really nice wood cubby under the heater controls.
Going through all this has made me work on making a combo kit using the original space of the base heater box, and instead turn the system to a combo unit like on other modern vehicles. Given how my day job is going, though, that is a long way out.
  • Like
Reactions: Dlc
6. the AC faceplate
7. the switchgear
#1 can be repurposed across E3/E9/Early E12 and E21 (with some minor changes on the hard lines)
#2-4 and 6 are E9-specific and require finding original or recreated/3D-printed parts
#5 can be repurposed across E3/E9/Early E12 and E21 and even E24
#7 outside of the knobs the wiring can be created easily and for switches standard aftermarket parts can be used
