E9 Front and rear coil springs
Since I'm awake in the early morning hours it's mid-day for Paul in the UK so we have been exchanging information. He is fine with me sharing this price list here, although he appropriately commented that this price list can change over time, especially the shipping amounts
Front Springs £140.00 each
Rear Springs £140.00 each
Discount for purchasing 4 springs - £60.00 (therefore 4 springs = £500)
Carriage (for 4 springs):
to USA £150.00
to Canada £150.00
Tariff to USA £60.00
Tariff to Canada £0.00
I asked about bundling shipping but his carrier caps out at 30 kg and each set of 4 is 17 kg so can't even get 2 full sets into one shipment. When I had initially emailed he said he didn't want to ship to the US but then suggested that he would consider it, perhaps one of us could be the guinea pig to see how well (or not) it goes.
Dang was just thinking that since we are both in Seattle that could have been a good option. I could be said guinea pig since I don’t need them anytime soon.
Well, if three of us in the Seattle area are going ahead it would be worth it, since he could make 2 packages of 6 instead of 3 packages of 4. I’m in if you are. And of course, we would report back. I think I would need some info from @HB Chris about what spacers exactly he used or best place perhaps to get them, but that seems straighforward
I used the stock e9 front spacer and two 2002 1/2” spacers for 1” in the rear. Actually one was 3D printed. Before that I was dragging the muffler and the front tow hooks on the ground entering driveways.
I messaged Paul and he sent me some info but said he isn't currently shipping to the US due to tariffs, etc. Looks like at least a few of us interested are in the PNW. I have a friend in Vancouver who comes to Seattle weekly for work - I could have a few of these shipped to him and then have him bring them south if @Markos and @Pittraider18 were interested in a group buy. Maybe we then need to have an installation party. I don't have the tools to install these, but glancing over at the 2002 forum, one of the first "here's how I installed them" threads was from a guy in South Seattle who was willing to lend another user his light duty spring compressor tool...
I've already got my set from Paul a while back awaiting install but thank you for the offer! I'm sure there will be a few locals who may be interested.
A
I thought you also referenced a 3-dot spacer?
Just cut ‘em.
(call me a shadtree mechanic.)
Look okay? Custom taylor the amount of drop with the spring rubbers
Right amount of drop?
Cavalier attitude? It sits low, and it is a tiny bit firm.. But it looks great. I had some Carl Nelson Springs, but they didn’t lower the car enough for my liking.
RP
I’m down for a group buy.
I don’t think I’ll need the spacers. I’m shedding 400lbs from my 2800CS. It’s all on paper based on the parts I already have and a few (expensive ones) that I need to buy. With that said, I’ll still need to shed 46lbs and haven’t figured out where to get that from. :D
Considered a diet?
@teahead @lip277 @skb @restart or any other PNW folks - anyone interested in being the third to join @Markos and me in purchasing some Paul Baker springs to save a bit on shipping?
Thanks - My car already has Carl Nelson's springs (his original from a while back) so I'm ok with springs. Those were installed when I got the car back in 2008. Seem to be working fine. That and the new wheels (via Don) work very well IMO....
Cheers....
You can also use the lowering springs of a early E24/E12 at the front axle. e.g. from H&R. They fit perfectly, but rear axle needs custom solution, e.g like shown by Patton.
See attached the result: The H&R lowering springs at the front axle are still very comfortable, even with the stiffer Bilstein dampers (at front and rear). Would buy the combination again.
Hony
Bumping this back up to see if anyone wants to join @Markos and me in ordering a set of springs from Paul Baker. Ordering three sets should cut down on shipping a bit. I can have them sent to a northern friend and then get them shortly after arrival. I can’t imagine shipping them within the US (especially west coast) would be ridiculously expensive so I guess if anyone wants to be the third, declare your intent
Just spotted this thread. I changed from a set of Carl Nelson springs.
I now have a set of Paul Baker springs on my car and really like them. That said, the rear was initally quite low. I used the larger US rear spring perch augmented by the stock US front aluminum rings to raise the ride height in the rears.
Ride is excellent.
Ride is excellent.
Do you know how much height difference there was between the CN springs and PB springs at the front? There was almost none between the German and CN springs.
@HB Chris - I have not provided feedback to Paul, but will do so.
Ian - Chris posted the front and rear measurements for the Paul Baker Springs here: https://e9coupe.com/forum/posts/372352/bookmark. Note that how the car sits is not only a function of spring height. Two springs of equal height would result in different gaps above the front tire if they have different spring rates. The stiffer spring will sit higher; the softer spring will yield more under the weight of the car. Rough cut, I think the Paul Baker springs result in the same gap above the front tire as the CN springs. My guess would be that free length is a little longer than CN springs given that the CN springs are stiffer.
