okay guys i have a couple of questions - all in the same area - inner fender, drivers side. a picture for background
1st - what wiring goes into the 'hook' near the coolant reservoir mount? - okay i realized the clutch master hose goes here.
2nd - the next is what goes into the 2 holes below the brake fluid reservoir? the small hole looks like it would be for a ground since the other side has the undercoating removed.
i know the big holes are for the brake lines to go to the caliper and i know i have a little bit of taping on the harness to pull it into the grommet thru the firewall.
