Power steering pump
edmil
West Yorkshire
I have an E9 with a failing power steering pump and am having difficulty in finding someone in the UK to repair it. They are no longer available new from BMW and although alternatives to the ZF appear to be available they are currently out of stock and bearings and seal kits seem to be a problem. Can anyone come up with a solution?
....they are different types, check which pressure / ID is shown on the label
Verify ZF-Id
Regards
Thomas
Failing how? If leaking you are on right path but if just making a weird noise like low power steering fluid....just in case: check tightness of the bolts that hold the "case" together. If loose pump can suck in air, with same effect as low fluid.
If you have the late pump (#2) easy enough to put a 13 wrench on the bolts just in case. If was internal resistance/something stuck belt would complain and be visibly slipping.
May be the bearings. There is a "relief valve" which regulates pressure accessible from outside on early pump. Clean and flush if you see any debris. There's a nice writeup on the rebuild process by @Stevehose
Threads on this forum have addressed power steering pump repair. Jay Stratton at jaysbmwparts.com offers rebuild services; his website illustrates the different pumps and lists the parts he installs in a pump rebuild. Some of those parts are supposedly difficult to obtain. I found him responsive to my inquiries by email at [email protected]. He's in California, but the illustrations on his site will help you determine which pump you have.
He did an e24 Highline AC compressor rebuild for us years ago, starting leaking after a few months.
Over here a renowned company specialising in repairing steering pumps and boxes offer an overhauled steering pump at 450€, with a deposit of 250€ for your one.
