Smokin' hot ignition coil
bluecoupe30!
I was working through a carburetor issue last week. After a long period of calm and smooth running, my Coupe suddenly would stall at a stop light. I am sensitive to that as this is an automatic and I had it dialled in to perfection, at a stop, in gear, it was idling fine, perhaps even as low as 550 rpm, but it did not matter, idle was strong, stable, and shifts from 2-1 were gentle. Not like when you must dial in a higher idle rpm to keep the car from stalling. This was set up great. Got it home and diagnosed a flooding front carb. (I have a pair of Weber 32/36s). Went through the usual measures, cleaning out all passages, adjusting float, replacing float, new needle valve and seat, new power valve, carb top off, then back on, over and over, ...until the progress bar of my "Fed-up" metre reached 100%.
Time for nuclear option. I had purchased a new Weber from Pierce Manifolds 4 years ago, for just this scenario. After 40 years, perhaps it was time to change to a new unit. Swap went well, except that overnight, one of the blocked off water hoses did leak and ran coolant out to below bottom of expansion tank. Was hopeful air did not get in. Filled tank. Time for a test drive. Car started great. Took drive, seemed to get hot pretty quick. Made one stop, then car was difficult to restart. Not normal. Drove home to investigate.
Next day I thought I would start with purging air from cooling system...and...this is where things got interesting. During the process, as car was running and heater was on full, and I was watching for the tiny bubbles of air escaping from the bleed screw, I observed, over by the ignition coil, smoke! Smoke, plus atomized oil...my coil was literally being boiled! Shut down immediately, disconnected battery.
I have owned this car 38 years. Ignition system has operated fine. It has always had a Crane XR700 electronic ignition. On that day, it died. A transistor failed, and it became permanently grounded and sent all its voltage into the poor coil and did not ever stop. Usually it is a pulse to assist in startup, but that day it seized.
What to do? Fast now makes the very same unit, and it is a virtual plug a play swap. But cannot get this in my hands quickly. I know Pertronix is popular, but again, there may be a delay. Add to that, the need to acquire a specific ignition coil....have you seen the prices now for a Bosch Red?
Decision time. I decided to rip out old Crane, revert to new set of points, condenser, rotor, cap, swap out coil with known good Bosch Black with factory spec Primary and secondary values. Car started and runs great again. I must say, it always helps to have spares on hand, especially as what used to be readily available ignition parts are now special order or days away, as well as much more expensive!
So, just when everything was going so well.....ah, the joy of owning/driving a 54 year old car. Mike
You should have a look at the rotor :
Hey Mike That is just a little hot Check out Mopac in Langley ( by the freeway ) for Pertronics stuff, they have a lot in stock, I was looking for 2002 set up a couple of days ago And coils as well Decent pricing
Thanks, Rick
Hi Rick. Did not know that. Thanks. What ignition coil would you suggest for a Pertronix setup. Do I need a Bosch Blue? Or would the factory spec Bosch Black with original .9 ohm ballast resistor work well with it?
Depends on which ignitor that you would get I would look at the ignitor II and the coil that goes with it I think that both are in stock out there and again, pretty good prices Do you have another rotor? I may have one in stock
I may have a coil that would work, currently Bosch Blue with my pertronix. You know that with petronix and the blue you would remove the ballast resister?
Yes, have followed all that. Taking it slow now that I am back running again. Simple can be great. Will see how car performs before making any new adjustments. Thanks for the offer.
Mike
Back in the points for daily drivers days, I think I recall 10-20,000 miles between replacements. It takes most of us several years to get that sort of mileage on a collector car. The Pertronics products (and other forms of pointless ignition systems) were great when we were driving those kinds of miles in a lot shorter time frame. Not so necessary for most now.
Don't you hate it when two systems (carb and ignition) fail at the same time. :( Good sleuthing and I'm glad it's back on the road.
Thanks Dick. YES! I was kinda bummed there for a bit, but when I thought about it, in the terms you just mentioned, I thought I would just "get back to stock" and perhaps that's all I need right now.
Cannot deny the two systems, teaming up, were, well, kinda daunting, but it helps that these are not daily drivers and we have time to think!
Mike
Thanks Rick, I had a stash of ignition parts, so got all this done and only investment was my time ;)
Dick:
I'd like to make sure I understand the above statement. I think you're saying that since we drive our collector cars so little these days (I know I do) that we might as well leave the points-n-condensor system in place, because it will take years for it to wear out. OK, I can see that. But aren't there some advantages to electronic ignitions, such as Pertronix, beyond the service interval? Things like a hotter spark, particularly at low voltage while cranking, greater reliability (new production condensors tend to be junk), etc.
I'm having a hard time seeing why I would ditch my Pertronix and regress back to a points-n-condensor. And if we introduce the subject of replacing a mechanical advance mechanism with a programmable, electronic one (e.g., 123 Ignition) the benefits over the stock ignition system are greater.
Dick:
Jay,
I agree that there are lots of advantages of one of the aftermarket ignition systems over the stock points. You name several, I'd add more accurate dwell and eliminating the tiresome task of dialing in the dwell on a stock set up. If your aftermarket ignition system is working well, I'd keep it. If it fails like Mike's did, I'd consider reinstalling the stock points...if not as a final choice but at least long enough to research the aftermarket options. I've tried Pertronix modules for other cars in the past (not BMWs) but I have never noticed a performance increase (acceleration, fuel mileage, ease of starting, etc) in so doing. When I have a stock points system that is working well I tend to keep it. But that's just me.
Jay,
OK, got it! Thank you for the clarification.
I too have temporarily re-installed points when the electronic ignition appeared to have failed. The root cause of that problem wasn't the Pertronix; it was a failed voltage regulator that allowed the alternator to put out ~20 volts, frying anything electronic, including my tach, as well as the Pertronix. Naturally, this happened on a Sunday, miles from home, out in the middle of nowhere.
Hi everyone,
I'd like to share my experience and my new issue. See what you experts diagnose and recommend.
I installed a Pertronix ignitor II paired with a Pertronix Flame Thrower coil (as recommended on their website). It immediately eliminated the misfiring, especially at idle and below 2000 rpm. It worked great for a few months. And then, little by little, the misfirings came back. So I thought maybe I should start replacing the complete chain, all the way to the spark plugs (which are already new). And so I replaced the distributor cap and rotor, and it instantly improved to almost perfect. But again, a few weeks later, slowly the misfirings are coming back. I drives me crazy. As I read somewhere here above "my 'ta-f*ck-meter reached 100%".
Interesting thing #1: the misfirings came back at the perfect same rate the temperatures are dropping here in Europe. Along with humidity. So I started also to wonder if there is some temperature sensor running to the ECU? Maybe needs to be replaced? Along with its wire?
Interesting thing #2: I tend to notice (but cannot be sure) that the misfirings are more frequent when I fill up with Regular gas than when I fill up with Pemium. (For future readers, in 2026 we're facing a global gas shortage because of the confilct in the Strait of Hormuz). Do you think this is relevant?
For the time being, I intend to continue replacing the remaining components downstream from the distributor cap—specifically, the ignition wires. I will make sure to select ones that are well-suited to my Pertronix setup. Finally, I might also replace the spark plugs; I’m considering iridium plugs. Do you have any personal experience with them, or any recommendations?
And if my misfires persist, I will work my way back through the system in the opposite direction—and likely switch to a 123 Ignition setup. I’ll just need to confirm with them that my Pertronix coil, ignition leads, and spark plugs will be fully compatible.
Thank you for taking the time to read this and for your responses.
Random thoughts?
Thirty plus years ago one of my cars ran the same XR700 bearing the Allison name, and it never failed. Same results with perhaps even older technology, i.e., Permatune (once favored by a few 356 and 911 owners) .
iu
iu
No quarrel with your failed transistor diagnosis. That said, the XR700 is older technology without the electronics found in the XR3000. Consequently, the 700 model apparently still requires a ballast resistor to limit coil current. https://static.summitracing.com/global/images/instructions/xr700 instructions.pdf Perhaps your ballast resistor also failed or affected the subject transistor and/or ignition coil.
iu
Coils also do not necessarily last forever. Although newer versions of older parts may change, conventional wisdom suggests that the OEM black coil is equal, if not superior to, the red version’s reserve performance. https://e9coupe.com/forum/threads/blue-coil-red-coil-black-coil.9501/ Along the same lines, consider that GM, Mopar and others employed equally durable 12V ignition coils for V8 engines that are virtually identical in shape and size - and - there are many aftermarket alternatives. E.g., https://www.partsgeek.com/catalog/1970/pontiac/gto/engine_electrical/ignition_coil.html
iu
As an aside, the picture of your rotor suggests that the embedded resistor is what actually cooked. “Some” advise employing a resistor-less rotor if available, or make your own.
https://www.da7c.co.uk/technical_torque_articles/bosch_distributors-ROTOR ARMS.htm
https://www.huelsmann.us/bugman/RotorTech.html
https://forums.pelicanparts.com/porsche-911-technical-forum/544061-ignition-rotor-meltdown.html
iu
iu
iu
iu
Interesting thing #2: I tend to notice (but cannot be sure) that the misfirings are more frequent when I fill up with Regular gas than when I fill up with Premium. (For future readers, in 2026 we're facing a global gas shortage because of the confilct in the Strait of Hormuz). Do you think this is relevant?
Sacré bleu.
The description of your vehicle’s symptoms could benefit from more details and possibly photographs. You mention “ECU.” Does this mean your engine is from a newer vehicle, or is it a csi, “djet?” This could be important in determining whether your misfiring issue is fuel mixture related rather than ignition related. (Pictures of your spark plug firing ends might be helpful.)
You mention “more” misfiring with regular, lower octane, fuel than with premium fuel. This first makes one wonder whether your ignition timing is too far advanced and/or whether your fuel mixture is too lean.
Next, since you suspect that the misfiring is somehow possibly spark plug related, exactly what plugs, including brand and number (heat range) are you currently using? Before going on and on, the general consensus is for you to consider using iridium spark plugs on your newer Japanese or Korean cars - - rather than your 1970's BMW.
