Fuel lines are straight, no flare or bulb
I have the HF trans jack. For a non BMW install, I found the load was a bit wobbly and the jack was very stiff to raise under load. As heavy as our engine and trans are, if I use the HF jack at all, it will be for each component separately.Great! I have that...
Is there a blanching act required when you have the sub-frame, engine and trans all married together? Seems like avery heavy, very long assembly!
Or are you suggesting doing the engine first and then using the trans jack to put in the trans?
Yeah, this is my concern too. I think I will build a crib that holds the subframe slightly higher than when it is in the car (which is not very high). I'll put it on large casters so it is easy to maneuver, and I'll use 4 bottle jacks at each corner so I can tweak the tilt of the assembly during installation, once it is positioned correctly. No interest in balancing the engine and trans with headers on a tippy transmission jackI have the HF trans jack. For a non BMW install, I found the load was a bit wobbly and the jack was very stiff to raise under load. As heavy as our engine and trans are, if I use the HF jack at all, it will be for each component separately.
There are some "full line" kits available, but even for those, the long rear brake line is coiled up. And there is no fuel line I have seen available.I have in on good authority that full brake lines will be available soon @ Ireland or direct from Andrew Adams
I used the Ireland engineering kit, mainly because it had the flare fittings on there. Don and Ed kindly asked if I had done flare fittings before and when my answer was “no, but I think I can figure it out” they suggested I had other ways to spend my time. The kit worked well, most of the bends were correct but a few needed tweaking. For the fuel lines as mentioned earlier I used 4lifetimelines and was pleased with the product.There are some "full line" kits available, but even for those, the long rear brake line is coiled up. And there is no fuel line I have seen available.
I have no problem making my own lines, and I can assure that they are correct, and of good quality.
I found a nice quality one I can borrow for postage... Ordered 2 sets of 25 feet of CuNi line and a pile of M10 fittings all from Belmetric.And while I always would support purchasing high quality tools, the $40 brake line straightening tool from the worlds largest store would work fine. It also allows bending but I found a hand-held bender a little easier to use. Could pick up both for about $60 if you can’t find any to borrow.
I also have all of the original lines to use as guides. And I have a very nice tube bender I got when I originally did a mini split AC system. I checked it, and it will work with 3/16 tubes. My thought is to put the original in the bender, and rotate the bender arms to get the right bend, then mark on the tube where the bender landmarks go. Transfer those to the new straight tube and replicate the bend. So that does the bend itself - all I need to worry about is the bend plane. But the wire idea seems like a good one..When bending lines from scratch, I've found it helpful to first make a template using 1/8" aluminum welding wire. It's rigid, yet malleable making it easy to form in-situ.
I believe this is what I have: Blue Demon 4043 1/8 X 36" Aluminum TIG Welding Rod - 1lb Pack
