Help identifying this washer
Paulaner
WA, USA
Found this in my jacket pocket and need help identifying.
Jacket hadn't been worn since last winter when I refreshed the front and rear end.
Its about 1in outer diameter and 9/16in interior diameter. Has a slight taper as you can see in the second image.
Bellhousing washer to the box itself is what comes to mind when I see this. Might jog your memory? Potentially crossmember or engine/trans mount?
Trans Mount is possible but I dropped that in June. Too warm here to be wearing the jacket then though. I'll look anyway.
Sorry should have included something else in the shot to show scale but it's about 1in outer diameter and 9/16in interior diameter.
It most certainly came from either the front or rear suspension or as @Pittraider18 suggested maybe the trans mount.
@sfdon - excellent guess but no dice. That one is installed. But you have a good eye. The washer in question is the same size
