Help identifying this washer
Paulaner
WA, USA
Found this in my jacket pocket and need help identifying.
Jacket hadn't been worn since last winter when I refreshed the front and rear end.
Its about 1in outer diameter and 9/16in interior diameter. Has a slight taper as you can see in the second image.
Bellhousing washer to the box itself is what comes to mind when I see this. Might jog your memory? Potentially crossmember or engine/trans mount?
Trans Mount is possible but I dropped that in June. Too warm here to be wearing the jacket then though. I'll look anyway.
Sorry should have included something else in the shot to show scale but it's about 1in outer diameter and 9/16in interior diameter.
It most certainly came from either the front or rear suspension or as @Pittraider18 suggested maybe the trans mount.
@sfdon - excellent guess but no dice. That one is installed. But you have a good eye. The washer in question is the same size
Going back through all my old photos now of when i did the front and rear. here are some potentials ill look at on teh car later.
Diff carrier:
1793814080454-png.229297
Trans support bracket
Subframe mount:
Control Arms
9/16” is ~14mm, so I’d venture to guess it’s a washer for an M14 bolt.
The trans support bolts are M8. The subframe mount bolt seems like a match, at least in regards to the thickness.
Do you have the car handy? You might find an exact answer if you check out the suspect areas.
Have gone through what a thought were the most likely candidates and have come up empty. Nothing rattles, nothing shakes. I'll leave it alone for now. Eventually I'll find it.
Thank you all for your suggestions.
