You need used e3 or e9 pedals, the bracket remains the same. I think you can even use the long bolt that they attach to.
Yes, with my 72 I reused the bolt that was in the car. I did not change my pedal box.
When I did my install, I read Carl Nelson's article dozens of times:
https://e9coupe.com/forum/threads/5-speed-conversion-carl-nelson.41993/ Highly recommended.
Some suggestions/modifications to Carl's write up:
- Buy a new driveshaft from Armando at DriveshaftPro.
https://www.driveshaftpro.com/Garden-Grove. Used driveshafts are likely to be problematic and if they give you trouble, they cannot be rebuilt
- You want to use the more robust e34 m5 guibo (Armando will have this figured into the length of the driveshaft he sells because it is commonly done around here).
- Some of the parts you need can be acquired from Rock Auto inexpensively. For example, Rock Auto has clutch slave cylinders for around $20.
- For the transmission mount, The Coupe King style of mount is much more robust than using any of the stock BMW parts. The stock BMW mounts will leave the bolts very close to the slots in the body of the car. Coupe King is out of stock, but our own Hal Boyles has one:
https://www.2002sonly.com/product-page/getrag-265-support-bracket
- And speaking of Hal, he also reproduces the shift platform which is very hard to find:
https://www.2002sonly.com/product-page/getrag-265-shift-tower, and he offers a shift lever and shift linkage kit
https://www.2002sonly.com/category/e3e92000cs-products (I'm not affiliated with Hal, but I appreciate the fact that he has undertaken to make very specialized parts for our cars, so I talk up his stuff).
