72 E9 conversion to a 5 speed
RipTide
New Member
Alabama
What break, and clutch pedal configuration can be applied to a 1972 E 9 3speed automatic? What is needed for this kind of swap out to work. My engine and transmission are ready to go. The replacement and mounting of the pedals is troublesome.
I need some clif notes for this part.
Lots of good information on here, do a search for Getrag and automatic, I’m sure it will pull up some threads. There is a write up by Carl Nelson that I and many others used as the basic Bible with then some updates based on experience. Look through those and then if you have a set list of questions I’m sure people can provide input. The work for the transmission swap is straightforward, you’ll have a bit of additional work for adding the third pedal but many have done it before
I have a pedal box from an E3 if you’re interested, can dig it up and send some pictures. Let me know.
You need used e3 or e9 pedals, the bracket remains the same. I think you can even use the long bolt that they attach to.
Yes, with my 72 I reused the bolt that was in the car. I did not change my pedal box.
When I did my install, I read Carl Nelson's article dozens of times: https://e9coupe.com/forum/threads/5-speed-conversion-carl-nelson.41993/ Highly recommended.
Some suggestions/modifications to Carl's write up:
- Buy a new driveshaft from Armando at DriveshaftPro. https://www.driveshaftpro.com/Garden-Grove. Used driveshafts are likely to be problematic and if they give you trouble, they cannot be rebuilt
- You want to use the more robust e34 m5 guibo (Armando will have this figured into the length of the driveshaft he sells because it is commonly done around here).
- Some of the parts you need can be acquired from Rock Auto inexpensively. For example, Rock Auto has clutch slave cylinders for around $20.
- For the transmission mount, The Coupe King style of mount is much more robust than using any of the stock BMW parts. The stock BMW mounts will leave the bolts very close to the slots in the body of the car. Coupe King is out of stock, but our own Hal Boyles has one: https://www.2002sonly.com/product-page/getrag-265-support-bracket
- And speaking of Hal, he also reproduces the shift platform which is very hard to find: https://www.2002sonly.com/product-page/getrag-265-shift-tower, and he offers a shift lever and shift linkage kit https://www.2002sonly.com/category/e3e92000cs-products (I'm not affiliated with Hal, but I appreciate the fact that he has undertaken to make very specialized parts for our cars, so I talk up his stuff).
Very true with the third pedal.the existing brake pedal has a bend to distance it from the accelerator. So I'm thinking a new brake pedal is needed.
This question comes up every couple of years. The search function is your friend. Like Chris said you a need both pedals. Only E3 or e9 pedals will work.
This thread reminded me to order a driveshaft!
Armando is fast. Ordered today and it's expected to be delivered the day after next. (Granted, they are somewhat local to me, so your shipping times may vary.)
Here are the pedals. I’ll send this bolt along but it looks a lot like the oil filter bolt so am wondering if it’s an extra of those. It does fit appropriately through the sleeve and if it’s not correct let me know. Regarding price, seems to be all over the map over the years - $150-325 is what I’ve seen. How about just below median at $200 but if that seems unreasonable let me know. Shipping should be under $20.
i have bought / installed many of the products from @halboyles and i want to reiterate that these are beautifully made and work perfectly on our cars. Highly recommended. THANKS Hal ...
