For printing, I use top-quality filaments from brands such as
Siraya-Tech, Polymaker, and Fiberlogy.
There’s no room for compromise when the goal is the highest possible print quality.
I can print an ultra-durable, "armored" cover for you—using a technical-grade material with 100% infill—and then further strengthen it through an annealing process.
You wouldn’t be able to break it, even if you jumped on it...
After you scan can you down size the exterior surface to allow for leather?
That would be an exceedingly simple modification. At that point might be worth taking the part to an upholsterer and asking if there are some other modifications that would make covering in leather much easier for them before you end up printing it. May as well play to the audience.
Yes, I always do this when designing parts that are to be covered with material.
I factor the average thickness of the leather/vinyl—or any foam backing—into the design.
I don’t use flocking on the inner surfaces of these components, as it tends to crumble and cause scratches over time.
I have an upholsterer who works wonders with Alcantara...
Vinyl and Alcantara.
