Worn Out Door latch
Rek
Islington London England
Has anyone had this happen. The teeth of the second part of my door closing mechanism has worn out or been eroded down. Instead of two nice angled teeth, the second teeth has worn down to the extent that the door only catches on the first one. The movement against the seals means that it cannot operate the second catch and requires a shove with my backside if I am out of the car or window down and a mighty pull with my elbow if I am in it.
The images show the first tooth 1, and the worn down tooth 2. with part of it not worn down behind it. Despite being less strong on the release the lateral movement of the door needed to close is more than that with a solid non-worn tooth.
It's the drivers door and is due to wear and tear. I think that someone else might have experienced this. Is there any solution?
Yes I do on both sides. It shuts well but only when shoved with some considerable force but this is a wear and tear item which affects the door mechanics.
If anyone has a spare then I am in the market, otherwise I might dismantle and have a blob of weld added and file it down, if this is possible.
If it holds the second position when close forcefully, may want to try adjusting piece on the b "post" a bit outwards?
Any play in the hinge - does the door sag any just before engaging? Any difference between window up and window down?
Tried that. It just means the door juts out a little more.
