Rek
Has anyone had this happen. The teeth of the second part of my door closing mechanism has worn out or been eroded down. Instead of two nice angled teeth, the second teeth has worn down to the extent that the door only catches on the first one. The movement against the seals means that it cannot operate the second catch and requires a shove with my backside if I am out of the car or window down and a mighty pull with my elbow if I am in it.
The images show the first tooth 1, and the worn down tooth 2. with part of it not worn down behind it. Despite being less strong on the release the lateral movement of the door needed to close is more than that with a solid non-worn tooth.
It's the drivers door and is due to wear and tear. I think that someone else might have experienced this. Is there any solution?
