Quick temporary Euro to US (KM to MPH) fix to the speedometer - make a quick circular overlay
dbrogdo4
Birmingham, Al
Didn't want to tear my dash apart to replace my Euro speedometer and replace it with a US MPH one. Then I would have to get the miles run up on it or go with zero or whatever. Another option is to redesign the speedo label to MPH and then probably get to recalibrate the gearing? Not really sure. Anyway, I came up with the idea to just put an overlay over the front of the glass that is circular and reads MPH in the outer ring. Seems stupid and a little awkward on the surface, but is working on me. I dropped the idea with ChatGpt and we went to work. I gave it the outside diameter measurements of about 3.5 inches, gave it a picture of my current speedo, and it gave me back a full circular pattern on a full sheet that I printed. I then lamented it to add stiffness and cut it out. I have attached the finished picture. I am the only person that can see it in the car and I can use it as a training aid to learn the metric readings quicker. It might keep me from a speeding ticket. I am thinking I can print black letter on a clear stock paper and it will be more transparent at night, but haven't done that yet. I am attaching the .pdf file, if you guys would like to try it. Also attaching a left and right image files to be printed on a T50M label maker.. I have one and it prints on the longer 2 x 3 labels, vertically. So you could then cut them out and just stick them on a little more permanently. The labels should peel off with a little bit of hassle down the road. So far I am happy with the stiff lamented circle. It seems to wedge in nicely. Cheers!
  • BMW_E9_MPH_Large_Font_REISSUED.pdf
Clever solution! Getting the speedometer out is...a bit of a challenge. It's not impossible and if you ever need/want to I have a MPH gauge. But your solution clearly works as the training aid so nicely done.
@dbrogdo4, what diff is in your coupe? i might have the appropriate mph speedo. i know you already made the card ... but its pretty simple. one thing that your change won't fix is the odometer reading in Km. so what part of b'ham are you in? i will likely be there in about 5 or 6 weeks to visit my brother in Hoover.
cheers
scott
I see that your tach is not calibrated to US standards. Revolutions here in the states seem to be somewhat different than in Europe...Just sayin';)
For example Britain has had no revolutions, which seems to be oddly appropriate given Lucas the Prince of Darkness. And some countries are in constant revolution, which means the tach needs no zero marking....
good question. Let me investigate. Greystone Country Club, which is part of Hoover.
that's part of Hoover? isn't that south off of 280? i've gone to a wine store out that way
in the meantime, in the FAQ, there is a section of diffs + speedos
Don't mind pulling the dash, cause I am getting ready to put the Oldenzaal A/C kit in the car. I am not sure what to do with the odometer on a new or used gauge. I guess one of the speedo shops in California can adjust to match the original converted KMs to Miles? Would be nice to stay close. I assume the calibration is slightly different for MPH, so I might need a new gear or cable?
Had the same problem in my H1 Hummer. I changed the bulbs behind the original speedo and still couldn't see it at night, so I converted to a newer bright GPS based unit. Love it, but the miles started at zero. I had just completed an engine swap out, so I just documented the start of the new equipment and still have the old gauge for folks that are purist. Sense it is vintage, not sure who cares to worry about it? We don't do annual inspections in Alabama and the same vintage tag last forever.
my answer on the gearing question is that I assume it is a 3:25.
Don't know about the open or locked? Only cause I believe it is an original setup for the CSI 4 speed manual in Europe for 1974. Or at least that's what I have been reading. I will know more, once I put it on my rack. Too many other projects lately. Getting close to BMW play time..
Well, so that's another option actually. For various reasons I had installed a GPS-based speedometer on my MGA, now have converted it back to standard cable since I was able to source the right cable. You could go the GPS speedo route and not have to worry about the conversion.
The GPS Speedo is just a gps box that has an output that plugs into the back of the speedometer. So if you get the mph Speedo from Rsporsche or I have one, you would just have the box plug into the back of that speedometer instead of the cable from the transmission. You calibrate it by driving at 60 mph and adjusting the speedo needle up/down with a button on the box.
Annnnd, you may get speeding tickets while driving in tunnels....:oops:
