dbrogdo4
Didn't want to tear my dash apart to replace my Euro speedometer and replace it with a US MPH one. Then I would have to get the miles run up on it or go with zero or whatever. Another option is to redesign the speedo label to MPH and then probably get to recalibrate the gearing? Not really sure. Anyway, I came up with the idea to just put an overlay over the front of the glass that is circular and reads MPH in the outer ring. Seems stupid and a little awkward on the surface, but is working on me. I dropped the idea with ChatGpt and we went to work. I gave it the outside diameter measurements of about 3.5 inches, gave it a picture of my current speedo, and it gave me back a full circular pattern on a full sheet that I printed. I then lamented it to add stiffness and cut it out. I have attached the finished picture. I am the only person that can see it in the car and I can use it as a training aid to learn the metric readings quicker. It might keep me from a speeding ticket. I am thinking I can print black letter on a clear stock paper and it will be more transparent at night, but haven't done that yet. I am attaching the .pdf file, if you guys would like to try it. Also attaching a left and right image files to be printed on a T50M label maker.. I have one and it prints on the longer 2 x 3 labels, vertically. So you could then cut them out and just stick them on a little more permanently. The labels should peel off with a little bit of hassle down the road. So far I am happy with the stiff lamented circle. It seems to wedge in nicely. Cheers!
