Quick temporary Euro to US (KM to MPH) fix to the speedometer - make a quick circular overlay
Yes I used their speed box with m12 cable. I no longer need mine if you want to try it as an option. It takes about 20-30 sec at startup to acquire a signal and yes tunnels were interesting!
Definitely learned something today. The speed box concept is new to me, but makes perfect sense. Now I really need to decide about swapping out speedo to US display. Once I head down that path, do I swap out the fuel guage, then the tack, etc.? Then do I change the blower grill writing to English? Might be a lot easier to get use to the metrics. I ordered clear transparency paper to reprint my conversion dial for this weekend. That way it will be a true see through overlay and the dash lights will show through the numbers. It will definitely help in my learning process. I may play with both red and black numbers on the overlay to make it easier for my eyes to go to the US numbers.
Question: what is the best way to deal with the odometer, if I were to change the unit out. Do or can the speed shops run the miles up on them to match the original KM converted units or do you have to live with the discrepancy? I saw something about signing a federal document that the speedo was adjusted or something?
I have a Euro 635 that had been converted to US gauges. I converted is all back to German, including the fuse box cover that tells you what fuses are what.
I was kidding about the tach. The only thing that is different is the speedo/odo. You will get used to the switches being in German. The fuel gauge has no units, nor does the temp gauge. Clock is also unchanged...(other than the time zone ;) )
I find there is something fun about "warnblinker",and "nebel"
Regarding the odometer, I think you record the current mileage on the old odometer in km, record the reading on the newly installed mph gauge and then just keep track from there. Most of these cars are old enough that any future sale is somewhat going to be TMU…mine reads 24k km. I assume that’s 124k, but could just as easily be 324k. Only way I have any confirmation is service records.
sounds good with me. I sort of like the idea of just keeping it with the original gauges and see if I can get use to them. With my new training aid printed in clear plastic this weekend, it might be a fun way to learn. Plenty of time to start reworking. Thank you all for your kind suggestions.
Easy way to get a simple calibration: 100 kph is 63 mph, 50 kph is 31.5 mph
stick your phone behind the gauges and take a pic of the back of the speedo - you might have to shoot some light up there. but you might be able to get a pic of the w# on the back of the speedo ... that will confirm what diff you have. it will also tell you what MPH speedo you would need.
3.25 KPH W= 0.679
3.25 MPH W= 1.078
3.45 KPH W= 0.7125
3.45 MPH W= 1.14
3.64 MPH W = 1.2164
3.25 KPH W= 0.679
3.25 MPH W= 1.078
3.45 KPH W= 0.7125
3.45 MPH W= 1.14
3.64 MPH W = 1.2164
Not sure about these numbers.
My car is a 1972 US car. It seems fairly stock.
I removed cleaned and sold the diff which was a 3.64 LSD. It has an mph speedo, but the numbering (below) is W1.14...
I'm hoping It is for a 3.45 diff, since that's what I'm putting in the car, but US 3.45 seems fairly rare...
US 2800s got the 3.45 and the e12s had them as well so not too rare, all US 3.0s had the 3.64 to accommodate for the drop in CR to 8.0:1 and the added emissions equipment.
your speedo is for a 3.45 since it is a w1.14 ... that is unless somebody changed the gear inside to match the 3.64 diff
