Door Seal Installation Help
dspoljaric
Hi all,
I recently received a new set of door seals from Germany and am looking forward to installing them. However, I've hit a snag with the left front door seal.
I start by aligning the seal with the 90-degree corner, then feed it into the groove, working downward and toward the front of the door. So far, so good!
However, as I continue around the bottom of the door, I discover that the seal is twisted and won't lie flat around the entire perimeter.
Thinking I had made a simple mistake, I removed the seal and started over, paying particular attention to its orientation. Unfortunately, I ended up with exactly the same result.
This isn't rocket science, so I'm struggling to understand what I'm missing. Is there a particular installation sequence or technique I should be following?
Any guidance from those who have tackled this job would be greatly appreciated. Thanks!
1972 e3 / VIN: 3103558
Door seal part numbers:
  • Front left: 51211847033
  • Front right: 51211847034
  • Rear left: 51221800077
  • Rear right: 51221800078
The two first pics show how the gasket is seated starting at the corner, and downward towards the mirror, and downward toward the door latch. The third pic shows that if I press the gasket up against the door frame as it should be glued in place, and follow that line around the bottom of the door when I come up the other end, the gasket is twisted (4th pic).
If I reverse the path going from the front of the door and seat the gasket and follow it around the bottom, it will twist when it returns at the door lock.
I'm starting to wonder if it is a defective gasket - as if when the gasket was made it was seamed while twisted to begin with.
Is the gasket connected to make a full loop, or is there cut in it at the bottom middle?
If connected you may want to try cutting it at the bottom so you can untwist it to get it straightened and get a little more length out of the piece
Thanks Kyle - the concern I have with cutting it is that you loose the ability to slightly stretch the gasket as the gasket adhesive dries, and it may separate later. When I lay the front passenger gasket down on the floor it appears to run flat and so I am thinking it might be a manufacturing defect. More to come...
yes, must be a defect. That's the only explanation for why the seal is twisted on the section. That's a bummer, especially knowing how expensive these seals are. What vendor was this purchased from?
I'll check mine out and see. I got mine from W&N and the front right fit well, but the rear right has been very tough. It fit well, but I cannot get the door to close properly..adjusted a million times and can't seem to get it...almost like part of the seal is too thick in the wrong place. I haven't done the other side yet, so I'm not sure how those will go. Definitely not the easiest things to install...
