Hi all,
I recently received a new set of door seals from Germany and am looking forward to installing them. However, I've hit a snag with the left front door seal.
I start by aligning the seal with the 90-degree corner, then feed it into the groove, working downward and toward the front of the door. So far, so good!
However, as I continue around the bottom of the door, I discover that the seal is twisted and won't lie flat around the entire perimeter.
Thinking I had made a simple mistake, I removed the seal and started over, paying particular attention to its orientation. Unfortunately, I ended up with exactly the same result.
This isn't rocket science, so I'm struggling to understand what I'm missing. Is there a particular installation sequence or technique I should be following?
Any guidance from those who have tackled this job would be greatly appreciated. Thanks!
1972 e3 / VIN: 3103558
Door seal part numbers:
- Front left: 51211847033
- Front right: 51211847034
- Rear left: 51221800077
- Rear right: 51221800078
