72 3.0 CS 2240344 Restoration
Those look great. How will you be getting your vacuum source for your MC booster? What kind of carb linkage will you be using?
I'm going to try tapping directly into the barrels with a small brass fitting, and then piping that over to a larger manifold that feeds the booster. All hard lines connected with short hoses to avoid vibration.
My plan is to draw vacuum from each port, so all of them are the same, otherwise if you draw only from one port, that cylinder will briefly go rich when you apply the brakes, and go lean when you let them off. That's my theory anyway.... ;)
I have a nice hexagonal shaft throttle linkage I got from Australia.
Here are the fittings I am thinking of using. I'll daisy chan these along the tops of the manifolds and then feed that into a larger hose and check valve for the booster.
On another note, I located a spring that should work as a replacement for the headlamp adjusting springs (mine are a mess).
