Hood cable snapped tonight
61porsche
Dallas
at the ferrule on the hand release. The parts diagram shows a "bush" and bowden cable.
For anyone who's had this problem and bought the part- I'd rather have the cable assembly with the ferrule swaged on rather than me doing it on a bench.
Do I need both parts to make one or is the cable complete?
Lucky it happened there - I've wondered what would happen if it snapped inside - how would you get the hood open?
Lucky it wasn't
a Porsche. You actually have to drill out the covers to to brake fluid resevoir and fish for the latch. I've heard and seen cars that guys cut a piece of floor out.:confused: Sometime after 64 they started putting an access plug in. Times change- check out Amelia Island's auction on Porsche- some serious money. There was a 2002 that sold too.
The BMW fails open. So no worries.
I can order the parts. But any bicycle shop has ferrules. I just can't tell from the parts description if the cable is complete or you have to make it up from two parts anyway.
J - happened to me on a road trip to S. Cal. IIRC the new cable comes with a crimped end piece and the bushing just slides onto the other end of the cable. It is a bit tricky getting it into the lever assembly. I think I unbolted it so I could turn it around and manipulate it.
Thanks...
The other end is fine.. still clamped up.
Oh well, good reason to detail up those catches and clean up the bilge.:!:
I've seen hydrualiic crimpers and didn't want to pay for a $200 tool for one time use on a 6mm cable.
Jaymic csbd 5090
Hi
See ref. part in the link. I bought it and fits perfectly.
Don't loose the bush in the handle that tight the whole thing.
As good as originall for 6.69 GBP.
http://www.jaymic.com/shop/parts_CS_products.asp?grp=CSBD
rgds.
That's
the part. The wire snapped clean at the end of that fitting on release. Ordered the part today. ( Well just had two add a thing or two.)
Thanks for the help guys.:smile:
