The shaft between the pedal arm and booster needs needs to be shortened. If you are out of adjustment you will need to fab a shorter version. This has been handled in creative ways by several members. I took about 2" off of the CS brake rod to put it in the middle of the adjustment.
I am running into an issue with the 3.0 master TII booster connection.
With it tightened up the master it is actually activated a tiny amount. Brakes are slightly on. If I turn the nuts out about 5-6 turns the brakes are dis-engaged.
The connection between these two parts has no adjustment.
Any ideas?
Thanks.
