i am planning to use early e24 seat belts mounted in the low part of the B pillar with extra steel connecting everything to support the seatbelt mount ... its all about figuring out how to support the pivot point
RobAnother DIY belt keeping option made from a BMW belt clip (from e23 b-pillar). You have to drill through the bumper and tap the steel plate within the bumper.
Yeah, this is a nice "clean" looking solution. The one benefit though of going over the top of the headrest bolster is, if ever passengers get in/out of the rear seats, the belt can be slipped out of the top-side clip and thereafter it drops to the floor and is well out of the way for passenger entry. Once you go under the headrest bar the belt is affixed to the upper seatback until you get a wrench out. Pretty minor though.I really like this option. It mimics what all of us have been trying to accomplish with the strap or cleat along the top edge of the shoulder bolster.
Also if you are tall it better with the belt over the headrest bar.The one benefit though of going over the top of the headrest bolster is, if ever passengers get in/out of the rear seats, the belt can be slipped out of the top-side clip and thereafter it drops to the floor and is well out of the way for passenger entry. Once you go under the headrest bar the belt is affixed to the upper seatbelt until you get a wrench out. Pretty minor though.
My thought (not sure it is correct and hope I never find out) is that with the belt going over the top and then down to your right hip that the belt won't move off the headrest in frontal impacts at least enought to keep your chest off the non collapsible steering column. I doubt it would help much in other impacts,Agree about the over the top, I just wish there was a better way to secure it. For me the ultimate ideal would be this exact piece sitting above the bolster with an extension off of its back side which extended down and went around the support the way this one does. Removable if needed, no screws through the top bolster, no zip ties holding the cleat in place, etc. The cleat option worked but because it is designed for rope its opening was pretty wide and the belt still slipped out. I’ll message the guy who made this one to see what he can do
