Alpine gauge pod
D Calkins
Royal Oak, Mi & Montgomery TX
Does anyone need an Alpine gauge pod? I'm going to have these cut for me by Send Cut Send. $20 shipped CUSA
by the way, i have some other VDO series 1 gauges like these if you are in need. i know i have a 100 psi oil gauge and sender, and might have another water temp or another volt ... not sure which.
Thank you, Scott, for posting that. I used your 2d to create my 3d that send cut send will accept. I will also send anyone the 3d file also. I know that I want an AFR gauge and an oil pressure gauge but not sure after that. I will keep yours in mind.
....any answer to that question yet?
Does the last pic show the lower edge?
How much clearance at the top?
I am asked to do some with veneer front (like loudspeaker cover). Anybody interested?
Let's see, I will copy (your consent assumed) and verify. Thanks for your input!
Thomas
Pour info j'ai réalisé mon support en placage.
Just so you know, I made my stand out of veneer.
Il est juste un peu claire à mon goût.
It's just a little too light for my taste.
Your install looks exactly what I want to do. What gauges did you use?
Anyone have a cad file at SendCutSend for a metal mounting plate or can i use the one at beginning of this thread
