1972 3.0CSi - Riviera Blau Puzzle Project
Nice! A lot of work!
What about the air compresson? How powerful you have used as for sanding a lot of air is needed?
Have you been changing the gun's nozzles frequently due to wear?
No shame in getting help to push something across the finish line.
Most excellent work on the blasting. Looks a sight better than mine.
The compressor was a 3CV power, with a flow rate of 24m²/hr, 10 bars max pressure and 100L capacity. I usually use a pressure between 4 to 5 bars to blast the media. Between the outside blaster and the blasting cabinet, I think that I used about 6 to 8 nozzles.
