73 POLARIS E3 BUILD...Slowly..
Rear window in, just need to sand/polish the trim and put that in.
Rear sub almost ready..waiting on the correct bearings for the inside hub. It’ll be wild to have the rear end on its wheels!
*you can see the battery cables coming into the trunk..0ga should do the trick
Noooooooo!!!! Does it really? Seems like such a tiny little ‘rudder’ on the trim..shoot
*window goes in easily with one person, so I guess I can pop it back out..poop
Rear window came out without issue. Soft rubber seal, hot humid weather.. just peeled out..pheeew.. now I need to sand and polish the trim..yay..:-/
