- Messages
- 292
- Reaction score
- 76
I learned about the E12 exhaust heat shield here, and Pelican Parts happened to have one in stock. Barring that, it probably has to come from Germany. Had to re-remove the rear header to get it in there, but it works well. I just drilled a couple holes and used button head screws from the inside to mount it. With the IE headers, the rear pipe touches the shield. Probably still better than not having a shield. I banged the shield in a little, but it won't not touch.
It looks a little crooked from the front, but that's where it fit the best.
This side part seemed like it would catch rocks and dirt, so I glued some rubber to it and bent it up against the body.
Then I got started on building a custom SS exhaust system. I don't know of any exhausts for sale the connect to the IE headers, so the downpipes had to be custom anyway. Might as well do the whole thing. The front IE header comes out at a crazy angle, not parallel to the rear header, so not so easy to connect to. I didn't want to ruin the ceramic coating by welding to the headers, so I'm using slip connectors. Then another set of slip connectors are required for assembly at the merge collector, on account of the two headers not being parallel. From there it becomes 2.5" tube and goes to a 4"x24" magnaflow front muffler, then on to a 6"x18" rear magnaflow. Still need to create the final part that circumnavigates the spare tire.
The ground clearance is not bad at all, considering the lack of space allotted for the exhaust. I honestly think BMW forgot to include it in the original design of the car.
