On my 73 cs hearing a noise when I push in the clutch pedal,sounds like a pop
I can feel it in my foot? is it a pedal spring, does it need to be greased where the pedal attaches ?
taking a detailed look to your question, I have realised that you said "when i PUSH in...", so the "pop" is produced then !
addtional to the details that you can see in the preceeding posts, you can check this for more details on the system that probably can help identifying the parts:
http://www.e9coupe.com/forum/showthread.php?t=10559&page=2
I did not mentioned it there, but In the reasembly I used:
- a new spring from the support plate to the pedal
- new plastic bushings, embeded in LithiumMolibd.Castrol grease
the final result was exceptional
cheking the area the noise as "a pop" is difficult to imagine in that area, but "what is a pop" ?, ok lets go step by step:
1-provided the spring is there, it will work well or be broken, for sure it will be rusty, but there is no need of lubricating, the only possibility of a repeated "pop" whith a spring is that perhaps in its way touches something, a plastic sleeve, a cable,..., that will be my first step, to check that area
if you are worried about the spring, it is available at bmw dealer, you can remove it easily to check it if it is very rusty
2-the second step is to check the attachment point of the master cilynder, there is a chance of the plastic bushings to be broken, that is a possible cause for a repeated "pop" when you push, the broken part of the plastic causing the "pop"
the plastic bushings are available, and the assembly is simple, remove the nut, take out the bolt, put some grease, new bushings, and bolt and nut again
3- the third possible source for that "pop" is the rubber flexible cover of the rear end of the master cyl, mine was broken, and I do not remember any noise, but considering that if the years had made the rubber rigid I assume that you can produce a "pop" everytime you push the rod into the cyl
that rubber cover is available in the repair kit from walloth&nesch, see: (top right area are the contents of the kit)
4- the last point is some internal problem inside the cyl, but I am not really considering it as you have not mentioned any issue in the clutch performance
regards
